Which fan to use for my Afco Scirocco radiator?
onesickcrx
NY
So I ordered a Afco Scirocco radiator and I still need to order a fan for it. I searched seems like everyone's running something different. I would prefer a pusher rather then pull but I could use either. I would prefer to keep the plastic fan away from my T4 top mount do to heat. I want to buy whatever is going to work best of course.
Any quick responses would be great I am trying to finish up my Galant. I put it up on my lift trying to get it ready for the shoot out /ubbthreads/images/graemlins/grin.gif My new Shep trans and clutch setup should be here next week /ubbthreads/images/graemlins/devil.gif
I'm planning on running an FAL-115 with mine. Its a pull type only, 1500cfm, but the shroud is 13 1/2" x 15" so i can keep it offset to the passenger side to keep it atleast partially away from my manifold, and I have it laying around so its free.
Where did you pick up your scirocco at? Every place I know that carries Griffin and Afco doesn't seem to carry their scirocco.
onesickcrx
NY
no other help on whos useing what and what kinda temps they getting?
iLLeffeKt vr-4
NYC
I would go with a puller rather than a pusher if possible and if you get this one from summit its all metal so you don't have to worry about it melting. 2,950 cfm also helps a lot. I had a thicker civic radiator with a Spal fan that only pulled 1700cfm and the car never went over 205*.Temps usually hovered between 176*-193*. Your radiator is bigger than the civic radiator so I don't think you'll have any issues with cooling.
