Bought 1401/2000 yesterday! What should I do?
I bought 1401/2000 yesterday and the previous owner did something that I have never seen before. One of the pistons looks like to had a chisel taken to it all over the top and then punched right throught the center of it. Is this from something wrong with the engine or elsewhere? The t/3-t/4 turbo was demolished with the shaft seized in the turbo manifold and oil is all through the intercooler and piping. Is it ok to clean these out and reuse or should I just buy new ones? Here's a list of parts that came in it but the engine and turbo are blown.
ACT Mitsubishi/Eagle Eclipse/Talon GSX/TSi AWD (6
Bolt) 1989-92 Xact StreetLite Flywheel, 11.8 lbs 1
254.00 254.00
Greddy Profec Type S Boost Controller 1 309.00 309.00
Mitsubishi/Eagle Eclipse/Talon GSX/GST/TSi 89-99, 650
cc Injectors 1 349.00 349.00
ACT Mistubishi Eclipse GS Turbo/GST/GSX 1989-99 Heavy
Duty 4 Pad Race Disc Clutch Kit 1 308.01 308.01
Auto Meter Mitsubishi/Eagle Eclipse/Talon 1990-94
Single 2-1/16'' Pod 1 24.00 24.00
Mitsubishi/Eagle Eclipse/Talon GSX/GST/TSi 89-99 turbo
replacement Bolt kit, 4 bolts, 8 washers 1 45.00 45.00
002090
HKS Super Sequential Blow Off Valve 1 196.00 196.00
Apex Super AFC 2 (Black) 1 319.00 319.00
frank1
anaheim
the engine looks like it skiped the timing belt pretty bad /ubbthreads/images/graemlins/ooo.gif
dmj
orlando FL
crankwalk has a oem rebuilt shortblock for 800.00 buy it now an save yourself some money.
All the parts weren't listed.
Custom 3.5 inch exhaust from 9-Second racing $800
Whiteline coilovers: $1000
Sportmax 17x7 rims: $1,000
Goodyear Fuzion 245/40/17 tires: $1,000
Motor: $3700.00 New long block with T-belt, water
pump, oil pump .020 pistons, new lifters, remaned
head, remaned crank shaft, new bearings etc.
two motors available for mix and match,
Race tranny: $1700.00 with all new bearings, gears,
synchros, double 2nd gear synchro
Mitsubishi/Eagle Eclipse/Talon GSX/GST/TSi 89-94, HKS
Bolt on SSQV BOV flange adapter 1 75.00 75.00
Yonaka 22 in. Type 10 Polished Front Mount Intercooler
1 329.00 329.00
PLX Devices R-500 Digital Air/Fuel Data Logging
Computer 1 549.00 549.00
Auto Meter Phantom 2-1/16'' Mechanical Boost Gauge,
Vac/Boost 30 InHg/30 PSI 1 56.00 56.00
9 Second Racing Universal 2.5'' Intercooler Piping Kit
With Black Silicone Couplers 1 325.00 325.00
Mitsubishi Eclipse/Eagle Talon TD06 20G Turbo Upgrade,
1 1075.00 1075.00
Walbro Mitsubishi/Eagle Eclipse/Talon FWD/AWD
1990-1994 255lph-HP fuel pump 1 100.00 100.00
254.00 254.00
002090
