oil filter
mountaineerjeff
west virginia
I need to know if there is a oil filter that will fit on our cars, but is shorter. I have o2 clearance issues, and need it fixed immediatly. it already busted a whole in one
tsiboy
Los Angeles, Ca
i don't know if there is a shorter oil filter you can use, but this will solve you clearance issues
mountaineerjeff
west virginia
how hard is it to change the cooler? i was hopin to be able to pick up a filter so it can be done tomorrow
ktmrider
Tempe, AZ
Jeff get an EVO8 filter. It's not as long but has the same thread size and ring seal.
mountaineerjeff
west virginia
no. im using the filter that is listed for gvr4/TEL
so check out 3000gt&evo 8?
Yea, check out all 3 next time you're at the dealership. 3000gt one should be shallow enough.
mountaineerjeff
west virginia
do they all have to come from the dealer? or is that just the best place?
jepherz
KC, Missouri
I know the 7 bolt 4g63 filter is much less wide, and probably a little shorter. You can look up the part # for a '93 eclipse and you should find it.
mountaineerjeff
west virginia
wouldnt it have to be the same width?
fivestardsm
Middle, Michigan
No because the ring seals in tabout the same location, just the bodies are different diameters. Youll see if you get one. I'd try the 3KGT filter. Just go to autozone or advanced and find all 3 and do a comparisson.
mountaineerjeff
west virginia
i found a filter. it is tiny
napa gold #1365 ill get you picks later
4wheelsqueal
Shawano,WI
2g filters work too. they're small but they do fit and clear big exhausts.
Nabeel
K.S.A
click here
This what i am using it is small. The original filter will hit the downpipe for my setup so I used this.
Chad989of2000
Livermore, CA
Quoting ktmrider:
This works well, I have to use one due to my 3" downpipe cramping my style.
