exhaust studs
hey just wondering what the thread pattern is four our exhaust studs and the nut to match? anyone have a thread chart. cheers
M8-1.25 is the nut side... M8-1.50 is the stud (head) side
2G the outsides are M10-1.25... M10-1.50
SSStuds.com are great
GVR4_1057
Brucetown VA
They are different thread pitch from end to end? Really? That is just goofy.
atc250r
Orange County, NY
Quoting kryger:
I don't think that's right. The threads are the same on both ends for both M8 and M10.
+1 on the SSStuds.com for replacements.
John
those # are correct accordingly to a "snap-on" tap and die kit
the thread-pitch is tighter on the maniflod side to hold on the lock-nuts, (the rounded triangle molded into the top of the copper nuts)
89Mirageman
Stantonsburg, NC
Every exhaust stud that I have ever seen had the 8mm 1.25 thread pitch on both sides.
Wizardawd
Franklin, NC
Agreed, I don't even think there is anything on our cars that has a 1.5 thread pitch. Just about everything is 1.25. And i've swapped the studs both directions and they thread the same.
As for the larger outer studs, they started that in May 1992 (IE 7 bolt), but I would definately rec. upgrading to it. The outer bolts are quite prone to breaking.
Wiz
