vacuum hoses... pics added!
i disconnected the vacuum hoses and cant remember witch wayy is the right way to connect them back...can anyone help me?
Rausch
Cleveland, OH
Ok, the URL thing is just being a prick so....
Click on search, type this exactly: "vacuum diagram"
near the bottom, titled : I suck, need some help with vacuum lines
cOmpressor
Bay Area, CA
those are so confusing to me... how many hoses are suppost to connect to the intake??
Polish
NE, IN
Ha! Good luck with this car if you think a simple vacuum diagram is confusing.
Rausch
Cleveland, OH
^ Ok, do you have a question?
yes..is that what it is suppost to read??? i really need help the car wont start now and its my DD
Polish
NE, IN
It means you have it set to add 28% of fuel at idle.
No offense but get a new car, these cars are not for beginners.
Rausch
Cleveland, OH
/ubbthreads/images//graemlins/uhh.gif
Dude, No offense, but you need to do some reading.
im not sure if these are suppost to connect anywhere??
and this hose im not sure if it should be connected where the picture below this is one is at...
Muskrat
Lexington, KY
This shows where most those go. Your looking at the purge control valve and evap canister.
And I believe you have the line from the intake setup correctly.
slugsgomoo
Tacoma, WA
there are actually several ways to do this, this is just one of them. You could also tee the bov line for the mbc & whatnot and ignore the boost from the turbo, doesn't really matter. also you'd want to have a boost source either from the manifold or from the 'P' on the throttle body to send to your boost gauge or map sensor.
Oh, and if you still need things like the fuel pressure solenoid & whatnot, haven't done the egr delete, etc you might not want to do this.
I think i removed 12' of vacuum lines from my car /ubbthreads/images//graemlins/hsugh.gif
