TRANNY GURUS NEED HELP! JDM-RS TRANNY
I have a Galant VR4 JDM-RS and unfortunately i blew my tranny last week-end. I had it towed and pulled down the tranny, opened it up and saw my first gear in bad shape, missing tooth, and a few seized bearings. But other than the ones mentioned all seems ok. I tried sourcing a JDM RS tranny but no luck...I know someone is selling one at the FS section but chances of getting it is slim since i reside at Philippines.
So im left with no choice but to try and search for other possible ways...
Here's a few questions that i want to ask..
>Is it possible to get a the 1st gear from a non-rs AWD JDM tranny and slap it on my existing RS-Core?
>Or i can i just use the non-rs AWD jdm core and use the JDM differential to match the gear ratio on my rear? How do i match gear ratios using a different core?
I have a few non rs AWD jdm trannies around, i opened one and compared the gears and they are different....
ANY SUGGESTIONS AND INPUTS WILL BE MUCH APPRECIATED.
TIA /ubbthreads/images/graemlins/smile.gif
1gnasty
garfield nj
i don't see why not the dif between the tyranny's is the final drive, it will be the same as when people put gvr4 1st on t/e/l's well make sure to use a t/e/l 1st will not be as long as the gvr4 on, because the rs tranny has a close gear ratio u don't want 1st and 2nd to close to each other
OldHairyBastard
Northern Chicagoland Area
You can switch but the problem is that the diff gear out of an RS is bigger "more teeth" so you will have to use the RS case with the other gear set. The GVR4 trans cases are smaller in the front diff area and the RS gear will not fit inside. If you have them both apart you can try this and see that the RS gear hits on the machined lip of the GVR4 trans case. Just take the gear set out of the other case and match up the shims good for the proper play in the bearings and slap her back in. You will have different gear ratios as in 1st, 2cnd, 3rd, 4th & 5th some of these are the same but I know for sure that 1st is different.
Doug
Thanks for the replies.
Just to confirm...its better to install the whole non-rs core on the RS tranny housing than mix matching gears like putting just the 1st gear on my exisiting rs core? I dont have t/e/l trannies here in our country. Only JDM GVR4 trannies
Also, im going to install a fully built balanced and blue printed motor with cams, SMIM, dual springs and with FP3065 soon....which is more compatible a close gear ratio tranny or a standard gear ratio tranny? I was thinking that a close gear ratio would finish up the gears easily and will just result on more shifting.
Thanks.
Just an update...no way i can fit the non rs core on a rs final drive....they just wouldn't match. Im no tranny expert but gears spacing are far different.
Any more suggestions?
OldHairyBastard
You have to use the RS diff and drive gear in order to make it work. all of the rest of the gears must be out of the other trans including the center diff or the gears will not match up and you will have to place them into the RS trans case. Just to clarify You have to use the RS case, RS front diff, drive gear that is out of the RS which is the little gear that the front diff is driven off of & all of the rest of the gears need to come from the donor trans including the center diff.
Doug
Doug... Tell us why you know so much on this subject. /ubbthreads/images/graemlins/smile.gif
Bimmubishi
Boston, Massachusetts
http://www.dentsport.com/gallery/v/dsg/tech/w5m33/GearBox+Code.doc.html
(word doc that you can DL)
The ratios on the RS trans are different, which is why you're having trouble. You might be able to use 1st from an Evo 1-3 but I'm no guru myself. I think that the Evo has double syncro 2nd and the gears themselves might be wider. I know when I swapped 5th from an RS trans I have to my Evo gearbox that it was about 2mm narrower.
OldHairyBastard
Your funny!!! $^&*@#(*$&(#$&)#&$()#.--Viscous eliminator anyone?
