ihugzombies
This is the radiator fan sensor that sits at the bottom of the radiator. I can't seem to find which one this is exactly as the OEM ones seem to have the 2 paddles perpendicular to each other. The 2g sensor seems similar but the notch on the top of this one is different so I just want to be sure. This has the numbers 7L245M on the thread and a hallmark I can't make out.
The last thing I guess if no one knows, is there a sufficient replacement pigtail/sensor you can recommend that you use? I have this currently setup for a relay for the radiator fan.
