Galant VR-4 Forums » Galant VR-4 » Newbies » Smog issue - high HC at idle
mk2davis
398/2000
Galant VR-4 org Post #: 1245295 posted 02/06/19 06:31 PM     Remind Me!  Send Private Message   Edit Post
Many of you have been following my progress, and I appreciate all the help. Today I failed my CA smog test with the following numbers
RPM %CO2 %O2 HC Max HC Meas CO Max CO Meas
Idle 8.0 9.3 120 280 1.00 .14
2500 15.0 .3 140 48 1.00 .17
So at 2500 rpm I'm golden. Idle though.... not good. Smog guy wants me to get a new cat. Before I put down a small pile of money, does anyone else have any suggestions? When I put the new motor in, I replaced all my vacuum lines and torqued down all my IM hardware.
No CEL, car runs really well now that I've replaced my knock sensor. Exhaust does kinda smell "eggy".
All help is appreciated.
Posts: 81 | From: Ventura, CA | Member Since: 03/01/15 | IP: (47.148.36.232) | Report this post to a Moderator
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1245326 posted 02/11/19 08:08 AM     Remind Me!  Send Private Message   Edit Post
Someone with more knowledge should probably chime in, but the high HC is due to unburnt fuel. Is your ignition timing set correctly? ( There is a correct way in doing it.) Plugs fouled up? Leaky injector(s)? That is all I can think of at the moment.
Posts: 381 | From: Murray, KY | Member Since: 10/10/12 | IP: (2605:a000:1610:4) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1245338 posted 02/12/19 07:25 AM     Remind Me!  Send Private Message   Edit Post
Do a boost leak test too.
When I passed in IL (I realize not as strict) I ran the tank low, put a few gallons of 89 octane in, lowered the boost and got the cat as hot as I could before the test.
BTW, I ran a 2.5" high flow cat too, not stock
Might want to make sure a previous owner didn't install a EGR plate or something.
1992 Nile black w/sunroof
Posts: 5865 | From: central Indiana | Member Since: 08/06/02 | IP: (77.111.246.181) | Report this post to a Moderator
138/2000
152/1000
Galant VR-4 org Post #: 1245339 posted 02/12/19 07:50 AM     Remind Me!  Send Private Message   Edit Post
I had this issue when I snogged my Laser a few years back in Tahoe and as stated above check base timing, my issue was from being at like 8-10* timing, i set it to 5* and passed. The guy at the smog station was blown away with how low my numbers were after the timing was corrected.
138/2000
152/1000
Posts: 3546 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
moduleunknown
Schooner
777/2000
Galant VR-4 org Post #: 1245343 posted 02/12/19 03:23 PM     Remind Me!  Send Private Message   Edit Post
Same thing happened to me recently. Answer was... base timing.
'91 GVR4 777/2000
Posts: 165 | From: Chandler, AZ | Member Since: 10/30/08 | IP: (159.153.4.47) | Report this post to a Moderator
mk2davis
398/2000
Galant VR-4 org Post #: 1245346 posted 02/12/19 10:41 PM     Remind Me!  Send Private Message   Edit Post
So I had the cat replaced for 250 including labor, which where I live is a steal. The numbers are now in the single digits and I am totally street legal!
Yet, I can't shake the idea that maybe the new cat is hiding some dirty little secret. The base timing was set correctly by grounding out the connector. But that was before I sent the ECU off to be inspected. Just to be on the safe side, I'll recheck that. The plugs are new, as are the wires. The air filter is clean. The injectors were recently serviced by RC.
Eztoril
1450/2000
Galant VR-4 org Post #: 1245358 posted 02/14/19 05:38 PM     Remind Me!  Send Private Message   Edit Post
I might get heat for this suggestion but you can run a gallon of denatured alcohol with a 1/4 tank of gas and it will most likely pass. I've done this method in my m3 for years and passed ca smog no problem. Just make sure you fill it up with 93 after the test to dilute what's left in the tank. Fresh oil change helps too. Or obviously fix the problem whatever it might be. I also think the base timing would be a good place to start troubleshooting.
91 GVR4 1450/2000
2.3 Stroker
HKS cams
FP 3052
Spal puller
EVO MAF 3"intake
EVO8 560 injectors
EVO8 ECU tephramod v7
Walbro 255
FRH intake mani
EVO3 exhaust mani
44mm tial wg
EVO3 tranny
Edited by Eztoril (02/14/19 05:45 PM)
Posts: 51 | From: Irvine CA | Member Since: 08/31/16 | IP: (2600:387:8:5::86) | Report this post to a Moderator
Generated in 0.032 seconds in which 0.01 seconds were spent on a total of 13 queries. Turbo powered.
