Galant VR-4 Forums » Galant VR-4 » Newbies » Stutters and stalls on left turns up hills RESOLVED
mk2davis
398/2000
Galant VR-4 org Post #: 1244956 posted 12/21/18 06:15 PM     Remind Me!  Send Private Message   Edit Post
The car runs great putting around, on the freeway, and in the canyons ... most of the time.
On uphill lefts in the canyons, it stutters, idles but won't rev, and then sometimes stalls. If I turn the car off, wait 7-10 seconds, and then turn it on then everything is good again. It feels like a fuel issue to me, almost like the bowl is running low on a carbed vehicle.
My first guess was fuel pressure regulator, but from what I've read, if that was the issue I'd more than likely run too rich. Is there a fuel pickup in the tank that might have issues? Fuel pump maybe?
All this happened with more than a half tank of gas.
Edited by mk2davis (01/22/19 04:01 PM)
Posts: 64 | From: Ventura, CA | Member Since: 03/01/15 | IP: (2605:e000:634a:2) | Report this post to a Moderator
Eztoril
1450/2000
Galant VR-4 org Post #: 1244958 posted 12/21/18 08:49 PM     Remind Me!  Send Private Message   Edit Post
Check the end play on the crank. Start there. I'm not gonna jump to conclusions but it's good to know if it's in spec. This is a rebuilt motor correct?
91 GVR4 1450/2000
2.3 Stroker
HKS cams
FP 3052
Spal puller
EVO MAF 3"intake
EVO8 560 injectors
EVO8 ECU tephramod v7
Walbro 255
FRH intake mani
EVO3 exhaust mani
44mm tial wg
EVO3 tranny
Edited by Eztoril (12/21/18 08:52 PM)
Posts: 51 | From: Irvine CA | Member Since: 08/31/16 | IP: (68.4.45.125) | Report this post to a Moderator
mk2davis
398/2000
Galant VR-4 org Post #: 1244959 posted 12/21/18 10:21 PM     Remind Me!  Send Private Message   Edit Post
You are correct, rebuilt 6 bolt with about 100 miles on it.
mk2davis
398/2000
Galant VR-4 org Post #: 1244973 posted 12/24/18 08:13 PM     Remind Me!  Send Private Message   Edit Post
I got end play at .002", which if I saw right is at the tighter end of the spectrum. The motor is installed with belts, so that may or may not effect measurements.
I also installed a new stock FPR, which did nothing to address the problem. Not a surprise, but wanted to rule it out.
I did get the problem to repeat on a flat corner at a left turn light. Flat approach, 5ish pounds, downshifted for a quicker left, accelerated out of the apex, and it seems to be around 0psi (so the turbo is starting to spool) that I get the STUTTER. I laid off the gas for 4ish seconds, and everything was normal.
Next left a block later and a similar thing happened, although it took a lot longer for full power to come back. I think this is because the exit was on an uphill, so I was building boost and using gas at a quicker rate.
If anyone has ideas, I'm all eyes.
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1244975 posted 12/25/18 09:46 AM     Remind Me!  Send Private Message   Edit Post
Someone with more knowledge needs to chime in, but I believe there is a difference in gvr4 fuel pump hangers and dsm, and I think I recall that the gvr4 sits lower in the tank than the dsm. Maybe you have a dsm hanger?
Posts: 373 | From: Murray, KY | Member Since: 10/10/12 | IP: (2605:a000:1610:6) | Report this post to a Moderator
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1244983 posted 12/26/18 11:42 AM     Remind Me!  Send Private Message   Edit Post
Are you saying everything is good on a right turn? What does the bowl that your fuel pump sits in look like? Sounds like it is either removed or damaged, allowing the fuel to go to the right side of the tank and starve the pump.
Thom
1992 GVR-4 866/1000 (PTE 1200's, 16g, DSMLink v3, eagle/ross, .020 over, 272's, GC/AGX Coilovers)
Posts: 805 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (2601:803:c600:5b) | Report this post to a Moderator
mk2davis
398/2000
Galant VR-4 org Post #: 1244987 posted 12/27/18 12:18 PM     Remind Me!  Send Private Message   Edit Post
I am saying that the only time the symptom has revealed itself has been on left turns. All four occurrences has been on left turns. Maybe it's a coincidence?
The bowl was an analogy. I don't know if there is a bowl in tank, but I expect to see a tub. Once the Walbro gets here from A.P.E., I'll get into it and see what lies below.
866/1000
Galant VR-4 org Post #: 1244988 posted 12/27/18 12:48 PM     Remind Me!  Send Private Message   Edit Post
BY the bowl, I was talking about the part the FP sits in, to keep fuel at the pump pickup. Another possibility, of the pump in it is already aftermarket, is a tear in the rubber hose from the top of the pump to the metal line. If the pump isn't secured, and there is a tear, it could swing and cause the tube to open and cut fuel pressure
Thom
mk2davis
398/2000
Galant VR-4 org Post #: 1244993 posted 12/27/18 11:56 PM     Remind Me!  Send Private Message   Edit Post
So what the previous poster called the tub. It may be next week before I get the pump, but I'm planning on digging into the tank this weekend to see if I need anything else. I'll update this accordingly.
Posts: 64 | From: Ventura, CA | Member Since: 03/01/15 | IP: (2600:1012:b048:8) | Report this post to a Moderator
mk2davis
398/2000
Galant VR-4 org Post #: 1245073 posted 01/08/19 03:39 PM     Remind Me!  Send Private Message   Edit Post
FINALLY got my Walbro pump and kit, so I pulled my old unit out. At first look, everything looks to be okay; the sock was a little dirty, the bottom of the tank looked clean, the steel fuel line didn't seem to have any cracks in it, and the tub looks to be in place. So at this point it's looking like a rewire and the new pump will fix my ills.
And then I dropped my new pump. The feed nipple broke off, which is obviously frustrating. So another few days for shipping. Which is right when rain is coming for four days. Another week...
mk2davis
398/2000
Galant VR-4 org Post #: 1245081 posted 01/09/19 04:16 PM     Remind Me!  Send Private Message   Edit Post
While I was finishing up my wiring this morning, I did find that the ground was loose. No doubt, this is part of my issue if not all of it. The ground is on the rear wall of the trunk close to the trunk latch. It's always the simple things...
Eager Beaver
Galant VR-4 org Post #: 1245100 posted 01/12/19 09:53 AM     Remind Me!  Send Private Message   Edit Post
Was this the ground for the fuel pump?
Also, be sure to check that your ECU has the OEM ground wires/eyelets, grounded at their stock locations and that the case is actually bolted to the chassis with all bolts in place.
I see so many pictures of ECU's sitting on the floor (and no sign of added grounding), that it stands to reason to ask this sort of question.
C53A 1 of the ~1500
Posts: 1599 | From: THE Ottawa | Member Since: 03/05/05 | IP: (24.246.8.178) | Report this post to a Moderator
mk2davis
398/2000
Galant VR-4 org Post #: 1245169 posted 01/22/19 03:58 PM     Remind Me!  Send Private Message   Edit Post
Thank you for reminding me to wrap this up. It's always frustrating when you have the same problem someone else had, your reading their thread .... and then zero pay off.
To answer your question FE, the answer is a solid "Probably." I got another Walbro fuel pump (this one I didn't spike on the ground), upgraded the wiring with 10 gauge and a relay, and remounted the ground. Things seem to be flawless right now, but I don't know which of the three was the culprit. I want to reinforce the ground in the future for reliability, but as far as functionality goes everything is golden.
I have no reason to think the ECU isn't in its stock position and wiring, but I will certainly grab a flashlight and look that over.
I want to thank everyone for their help. A couple hundred more miles of break in, and then I'm off to smog!
Posts: 64 | From: Ventura, CA | Member Since: 03/01/15 | IP: (47.148.32.118) | Report this post to a Moderator
Generated in 0.041 seconds in which 0.005 seconds were spent on a total of 13 queries. Turbo powered.
