mk2davis
I may post a short video on YouTube so you all have a better sense of what is happening. As the title states, she runs, but it seems lumpy to me. I set the idle to 900 per vfaq instructions, grounding out the number 10 pin inside the cabin and the timing lead. Also set the timing to 5 degrees by only grounding out the timing lead. Is there something else that needs to adjusted? The motor is a new build. After a couple hundred miles, I'll drain the oil, and then it's off to CA smog.
The old fuel was drained, anda new fuel filter was installed.
