Galant VR-4 Forums » Galant VR-4 » Newbies » She runs, but the valves... RESOLVED
mk2davis
Galant VR-4 org Post #: 1244872 posted 12/12/18 02:26 PM     Remind Me!  Send Private Message   Edit Post
She has a reman'ed long block, and runs quite happily (for a total of maybe 20 seconds at idle), but the valvetrain are terribly loud. Being a fresh build, there is no residual oil. IIRC, the valves are hydraulic and self adjusting. Is this just a case of the valves haven't had time to adjust? I'm running cheap dyno oil for the first 100-200 miles for break in. I'm a big fan of Lucas, but don't want to disguise the symptom.
Any and all help appreciated.
Edited by mk2davis (12/14/18 12:35 PM)
Posts: 42 | From: Ventura, CA | Member Since: 03/01/15 | IP: (2605:e000:634a:2) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1244873 posted 12/12/18 04:44 PM     Remind Me!  Send Private Message   Edit Post
If it's the small port lifters, they just make noise. I have 2g lifters in my 1g and it still clicks. You need to get zero tick lifters if they aren't already installed.
Also yes hydro and self adjusting, but they may just need to be primed.
138/2000
Edited by transparentdsm (12/12/18 04:46 PM)
Posts: 3487 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (69.36.193.100) | Report this post to a Moderator
mk2davis
Galant VR-4 org Post #: 1244874 posted 12/12/18 06:38 PM     Remind Me!  Send Private Message   Edit Post
They are the stock lifters, and they've always made noise. This is like an orchestra vs a solo player. So I believe you are right, it seems like they need to be primed. Are they self priming, or is this something I was supposed to do already (and what is it that I need to do)?
138/2000
Galant VR-4 org Post #: 1244876 posted 12/13/18 09:23 AM     Remind Me!  Send Private Message   Edit Post
click something you should have done while motor was apart.
youll probably want to pick up one of these to not have to remove the whole timing or the camshafts. click video of how to use it click
what they dont mention in the tool video is you have to rotate the timing belt while you do it to put the top of the cam lobe as far away from the rocker roller as possible so the rocker comes out the easiest.
138/2000
Edited by transparentdsm (12/13/18 09:26 AM)
Posts: 3487 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
mk2davis
Galant VR-4 org Post #: 1244877 posted 12/13/18 04:02 PM     Remind Me!  Send Private Message   Edit Post
The long block came as a unit with the cams, valves, and lifters installed. This let me to believe everything was ready to go. And they are getting quieter as it runs, but they are by no means quiet.
138/2000
Galant VR-4 org Post #: 1244887 posted 12/14/18 01:42 PM     Remind Me!  Send Private Message   Edit Post
I see this is resolved, what was the prognosis doctor?
138/2000
mk2davis
Galant VR-4 org Post #: 1244891 posted 12/14/18 07:37 PM     Remind Me!  Send Private Message   Edit Post
Seems like every time I turned the car off and let it cool down, when it restarted it would be quieter. I wish I had a better story, but beyond asking nicely, I didn't do nothing!
138/2000
Galant VR-4 org Post #: 1244899 posted 12/15/18 10:21 AM     Remind Me!  Send Private Message   Edit Post
So the lifters naturally filled and quieted down, nice. They more then likely just weren't primed after the engine rebuild, unfortunately its common unless you have someone who knows these motors do it.
138/2000
1 registered and 14 anonymous users are browsing this forum.
Generated in 0.088 seconds in which 0.071 seconds were spent on a total of 14 queries. Turbo powered.
