Galant VR-4 Forums » Galant VR-4 » Newbies » Fuel filler tube RESOLVED
mk2davis
398/2000
Galant VR-4 org Post #: 1244866 posted 12/11/18 08:20 PM     Remind Me!  Send Private Message   Edit Post
I've read a lot of old posts regarding the availability of the rubber fuel neck tube, some of which were almost 10 years old now. I'm going to call JNZ just to verify that they are out. Does anyone know the size of the I.D., or a more modern application with a similar tube? I've read somewhere between a 41 and a 44mm, but it would be a lot easier if it was a 1.5" or 1.75".
Edited by mk2davis (12/14/18 12:35 PM)
Posts: 81 | From: Ventura, CA | Member Since: 03/01/15 | IP: (2605:e000:634a:2) | Report this post to a Moderator
DSSA
Old-Head
Galant VR-4 org Post #: 1244882 posted 12/13/18 09:16 PM     Remind Me!  Send Private Message   Edit Post
They are definitely gone as I indicated in the call. Members here got 3 of the last 4 I had, and I am keeping the last one for future use (personal eventually--but also for figuring out a replacement setup shortly).
The last hose I have here measures between 40-41mm I.D. (rubber hose is not easy to get an "exact" on), which would put it between 1 37/64" and 1 and 39/64". That said, they are a REALLY snug fit on the tank/fill tube, and a 1 5/8" hose would probably be the key if it has to be English Measurement hose. If it's got internal braiding, I would venture to say that a slightly larger ID (less flexibility) would be needed to slip over the beads of the connections.
Hope this lets you find at least a temporary solution.
Josh
JNZ Tuning
Posts: 554 | From: PA | Member Since: 04/16/02 | IP: (96.245.17.168) | Report this post to a Moderator
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1244890 posted 12/14/18 07:33 PM     Remind Me!  Send Private Message   Edit Post
If anybody else comes across this post, there is a course of action in another thread.
Posts: 380 | From: Murray, KY | Member Since: 10/10/12 | IP: (2605:a000:1610:6) | Report this post to a Moderator
1 registered and 8 anonymous users are browsing this forum.
Generated in 0.225 seconds in which 0.215 seconds were spent on a total of 14 queries. Turbo powered.
