Galant VR-4 Forums » Galant VR-4 » Newbies » Vacuum lines and connectors is all that's left RESOLVED
mk2davis
Galant VR-4 org Post #: 1244822 posted 12/07/18 07:45 PM     Remind Me!  Send Private Message   Edit Post
I just got a free things left to button up, but I'm kinda stuck. There are there things:
Front axles are kicking my ass, see other thread
I have a black rectangular box with two vacuum lines, one in and one out, which is currently (and most likely incorrectly) mounted near the firewall passenger side. I don't know where the vacuum lines go.
I have a little bracket with mounts to the rear of the stock airbox with two electrical switches and four vacuum nipples. I got the connectors figured out, the vacuum nipples....
Near the passenger headlight, right next the 6 pin fan connector is a 2 pin female connector, can't find the male side.
I know this sucks without pics. Once I learn how to shrink my pics, I'll add them.
Thanks for the help!
Edited by mk2davis (12/14/18 12:36 PM)
Posts: 42 | From: Ventura, CA | Member Since: 03/01/15 | IP: (2605:e000:634a:2) | Report this post to a Moderator
mk2davis
Galant VR-4 org Post #: 1244834 posted 12/09/18 10:39 AM     Remind Me!  Send Private Message   Edit Post
Eztoril
1450/2000
Galant VR-4 org Post #: 1244836 posted 12/09/18 03:29 PM     Remind Me!  Send Private Message   Edit Post
Have you looked at the "vacuum line" routing diagram on the hood, if it's still there? My car has it and if you need I can post a pic of it. Are you still using an egr valve and other components that require use of the vacuum lines? I think the 2 pin connector you are talking about goes to the boost control solenoid. I have never seen that black box looking thingy. I dont use those vacuum lines any longer otherwise I would just tell you where they go. You can figure it out by looking at the diagram, it's not that complicated
91 GVR4 1450/2000
2.3 Stroker
HKS cams
FP 3052
Spal puller
EVO MAF 3"intake
EVO8 560 injectors
EVO8 ECU tephramod v7
Walbro 255
FRH intake mani
EVO3 exhaust mani
44mm tial wg
EVO3 tranny
Edited by Eztoril (12/09/18 03:50 PM)
Posts: 49 | From: Irvine CA | Member Since: 08/31/16 | IP: (2600:387:8:7::1e) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1244844 posted 12/10/18 05:45 AM     Remind Me!  Send Private Message   Edit Post
That big black box, pull it off, on the other side I'll bet it says greddy, it should be a boost controller box for a old school profec b. The two vacuum solenoid's like like they are for the fuel pressure regulator, but repurposed as the OEM boost regulator.
138/2000
Posts: 3487 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
mk2davis
Galant VR-4 org Post #: 1244846 posted 12/10/18 01:24 PM     Remind Me!  Send Private Message   Edit Post
The box was for the greedy, so I pulled that off. Also found a trunk of vacuum lines that had slid out of sight, and those connected to the solenoids.
138/2000
Galant VR-4 org Post #: 1244848 posted 12/10/18 04:16 PM     Remind Me!  Send Private Message   Edit Post
Very nice, glad your working things out.
To bad your not closer to me, I've made about 4 vr4's in the Reno/Tahoe area smog ready, got pretty good by the last one.
Do you have that whole greddy set up? And do you plan to use it? I love those things.
138/2000
Posts: 3487 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (69.36.193.100) | Report this post to a Moderator
mk2davis
Galant VR-4 org Post #: 1244852 posted 12/10/18 07:33 PM     Remind Me!  Send Private Message   Edit Post
The greedy set up never seemed to work right for me. This car has had a few quirks, so I'm taking things out of the recipe to try and see if I can't get some driveability back
138/2000
Galant VR-4 org Post #: 1244859 posted 12/11/18 01:32 PM     Remind Me!  Send Private Message   Edit Post
dealing with someone elses fuckery is always a tough battle. with the age of these vehicles checking wiring under the loom is also a big portion of problem solving. ive had cracks in the harness where wires were exposed and touching themselves, causing false or no readings, this is almost always by the coolant temp sensor and oxygen sensor harness bundle and they can cause a bunch of stuff to act crazy.
if you have the full greddy set up and want to sell it let me know, im a sucker for period correct parts for these vehicles and wouldn't mind this in my VR4 once its back together and driving.
138/2000
mk2davis
Galant VR-4 org Post #: 1244865 posted 12/11/18 08:16 PM     Remind Me!  Send Private Message   Edit Post
I'll keep you in mind, but as this car was my dad's, I'd like to see the Greddy in it and working correctly.
EDIT: How often do you get to Tahoe area? If I have any issues, I might have to make the trip!
Edited by mk2davis (12/11/18 08:22 PM)
138/2000
Galant VR-4 org Post #: 1244870 posted 12/12/18 09:06 AM     Remind Me!  Send Private Message   Edit Post
I try to get there once or twice a year, but it's usually to go snowboarding. If you ever have issues just send me a PM, I'm always willing to lend any help I can.
138/2000
0 registered and 18 anonymous users are browsing this forum.
Generated in 0.096 seconds in which 0.071 seconds were spent on a total of 14 queries. Turbo powered.
