Galant VR-4 Forums » Galant VR-4 » Newbies » Fixing camber after lowering springs
TheBen12345
Newbie
Galant VR-4 org Post #: 1244811 posted 12/06/18 09:12 AM     Remind Me!  Send Private Message   Edit Post
Hello people,
Just wondering the ways to counteract the negative camber i got from installing lowering springs
Cheers in advance.
1991 galant vr4
Posts: 16 | From: Perth | Member Since: 07/02/18 | IP: (123.243.18.197) | Report this post to a Moderator
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1244812 posted 12/06/18 10:07 AM     Remind Me!  Send Private Message   Edit Post
I assume you are talking about in the rear? There is a camber adjustment bolt on the rear upper control arm, near the rear diff that you can use to adjust some of it out, but probably not all of it.
Thom
1992 GVR-4 866/1000 (PTE 1200's, 16g, DSMLink v3, eagle/ross, .020 over, 272's, GC/AGX Coilovers)
Posts: 799 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (2601:803:c600:5b) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1244813 posted 12/06/18 07:51 PM     Remind Me!  Send Private Message   Edit Post
FWD E38 or AWD E39 setup?
Very specific procedure for rear adjustments involving the removal of the rear toe joints on the awd rear steer models, so we need to know what setup you have.
As Thom stated some adjustment can be made with the factory setup but it depends on how low you went and how the car is setup.
C53A 1 of the ~1500
Posts: 1589 | From: THE Ottawa | Member Since: 03/05/05 | IP: (135.23.119.135) | Report this post to a Moderator
TheBen12345
Newbie
Galant VR-4 org Post #: 1244814 posted 12/06/18 08:28 PM     Remind Me!  Send Private Message   Edit Post
Sorry guys, shouldve given details haha.
Yes its the rear, and awd setup.
I am a noob so just some simple (cost effective if possible) ways to lessen the negative camber
Cheers
1991 galant vr4
Eager Beaver
Galant VR-4 org Post #: 1244825 posted 12/08/18 08:57 AM     Remind Me!  Send Private Message   Edit Post
Bulletin - Rear alignment procedure.
Click
You will still have to try and dial out camber, but at least you will have had a proper alignment done.
Rear to Front - Caster, Camber, toe is the usual rundown of how to perform a 4 wheel alignment, as the front compensates for whatever is happening at the rear of the vehicle - ie Pull, dog tracking.
There is only so many adjustments that can be made at the rear of the early 90's independent rear suspension, and camber isn't going to be that large an adjustment one way or another, as the car is not meant to be "bagged" or "dumped" very low.
If you have an alignment sheet showing what your car sits at currently or visually, we can at least tell you our thoughts.
That being said, if the car is sitting in the weeds or on the bump stops, there is no helping the situation.
C53A 1 of the ~1500
Generated in 0.093 seconds in which 0.079 seconds were spent on a total of 14 queries. Turbo powered.
