About to buy some wheels, pretty sure these should work
cptncreme
Austin
so i have a '91 galant vr4 lowered on h&r springs with kyb agx's. i am wanting to get the following wheels:
xxr 527 17x7.5 +40. These should fit just fine if im doing my math correct right? going to run 235/45/17's.
heres a link: click
heres the specs off the page:
Specifications
Wheel Diameter 17"
Wheel Width 7.5"
Color Chromium Black
Lip Specs n/a
Bolt Pattern 4-100/4-114.3
Offset +40mm
Backspacing 5.82"
Centerbore 73.1mm
Approx. Weight 20.9 lbs
Manufacturer SKU 52777082N
citymunky
Chesapeake, VA
it will work.
Sacramrnto, Ca
I was looking at these for my Galant but in an 18. Post pictures when you get them. I'd be interested to see how they look.
Cherry Hill, NJ
Quoting Lglracer352:
Glad to see you on the .org man!!
Sacramrnto, Ca
Quoting transparentdsm:
its been some time but starting to get back on the org.
How is the spacing between the rim and trailing arm?
Indianapolis, IN
Do you have perfect roads where you are? 18's are asking for bent rims since you will have to be so thin on the rubber to fit. 17's present real well and allow enough rubber to protect.
