Which radiator?
4dr_vr4
NC
It is time to replace my stocker and I'd like to replace it with an aluminum one. I have a 1g mishimoto laying around along with a 1g parts car to pull the thermo housing from.
I'd also like to keep my A/C. I have read the posts here on how to make the swap. Is there another better option that is aluminum and will allow me to keep my a/c or would you just use the 1g mishimoto and call it a day?
Being that the 1g is a bit shorter than the stock, I don't want worse cooling than I started off with. Would seem foolish.
Also, is there any all aluminum radiator out there that just bolts in and has the appropriate sensor bung at the bottom and has the correct fan mounts? I have enough stuff to tap and mount.
gvr4144
loveland Colorado
If you go the 1g route you pretty much have to delete your ac, use the 1g fans and thermostat housing. With that you gain alot of room and your coolant fill point is a bit higher at the head. Also any stock replacement you find will be aluminum and much lighter.
Eztoril
Irvine CA
I did a simple Google search and found this one at Amazon. Looks like it has the place for the fan switch at the bottom. I think it checks all the boxes for what you were looking for? I will try this one when I get to that point.
web page
4dr_vr4
NC
Thanks guys. You have to delete your AC to go the 1g route? Are you sure. I won't go without A/C.
The Amazon radiator looks like it has the bung but I am worried about fan spacing. That radiator is also sold on ebay and not sure if they are all the same but a quick search seems to show people having a hell of a time with Ebay GVR-4 radiators.
Eztoril
Irvine CA
Is it the holes for mounting the fan or something else about the fan? I use a slim spal fan and had to be creative to mount it. I couldn't imagine it would be that big of a hurdle to overcome? If you get it please do a review of it, if they made it a direct fit?
Looks like "vman911" got it to fit with slight modification. At least you can keep your ac using this one.
4dr_vr4
NC
Unsure, but good find on that thread. So what is it that makes you lose A/C by using a 1g radiator? Does it have something to do with that connector on the thermostat housing for the GVR4? If so, previous owner left that harness disconnected and AC works fine.
bobbybdemented
Active member
Magnolia, Tx
I have found out that a radiator from a EVO 3 will fit the Galant VR4 with very little mod. I had to add spacers to lift the radiator about a 1/2 a inch. I used hose that I slipped over the mount. Easy and works great!
Here is a link to the one I bought on Ebay. Pretty good quality for the Price.
Picture of mine installed with a Spal fan.
