I have a few 1g DSM(s) laying around (1gb FWD and 1gb AWD) that I am going to part out and get rid of. Before getting rid of them I want to make sure that I am not missing anything that would work on my GVR-4.
I know that there an infinite amount of parts that won't and will interchange but I want to make sure that I don't forget anything that could come in handy at a later date. Want to get whatever I can since I got burnt pretty bad on one of the DSM(s) and I am trying to reduce my losses.
I know that the list will be subjective since you don't know what each of the vehicles has or doesn't have.
Some things that come to mind are:
4-bolt rear
Cylinder head
6 bolt bottom end
Windshield Washer Bottle...(for more intake room)
Mishimoto Radiator (yes I know that some fab work will be required along with 1g thermo housing)
Door switches
Speedo cables
Shifter
ECU
Black top CAS
FWD lowering springs on KYB struts
Cross drilled and slotted rotors (not so sure I'd move over used stuff but better than my rusty stockers at this point)
Pedal Covers
Coil Pack
Ignition Module
Throttle Body
Fuel Pumps (Do a quick check to see if aftermarket)
Alternators
PS Pump (not sure if is the same as a GVR4)
Am I missing anything? Feel like I am.
Thanks.
4-bolt rear
Cylinder head
6 bolt bottom end
Door switches
Speedo cables
Shifter
ECU
Black top CAS
Pedal Covers
Coil Pack
Ignition Module
Throttle Body
Alternators
Thanks.
