1992 6g galant automatic transmission Idle problem.
wilson24p
New member
Balanga City, Bataan
hi guys. i have 92 6g galant automatic which we overhauled last two weeks ago. the problem is when in park/neutral mode it idle normally at 900 rpm but when i am in drive mode and reverse the rpm goes down to 650 rpm and it goes down as i turn on the a/c.i've check all the hoses for vacuum leak and its all ok. i hope someone can help me what to check with my car. thank you and godbless.
89Mirageman
Stantonsburg, NC
Have you tried to adjust the BISS? Also your ISC could be bad.
89Mirageman
Stantonsburg, NC
Yes, the idle stepper motor. Sounds to me like its not working. It's supposed to adjust and let more air in once a load is put on the engine.
