Will The VR4 panel trim fit on a NON VR4 fender
WesternMD_VR4
Hagerstown,MD
I found a clean 89 galant at the local junkyard, I have a big dent in my front passenger fender and for 30$ at the junkyard Im thinking of taking the fender off it. Problem it has this black plastic trim on it instead of those vr4 door panels, Im wondering if that can be attached to a non GVR4 fender.. the part on the lower VR4 fender
Toronto, ON, Canada
Yes it's fine. You may have to drill some holes for the trim clips though.
WesternMD_VR4
Hagerstown,MD
A headlight and grill are missing but besides that it's mostly complete, interior is mostly there it is all disassembled inside but all the interior pieces are just laying inside the car, and ill probably end up taking it then we actually started removing it me and my friend last weekend but there's one bolt (near blinker light at front of fender) that you would have to either remove bumper or get up underneath somehow, and we just couldn't reach it, maybe bring a dremel next time
jnava
Arlington, Tx
That's what I thought, get those bits.
2000GTX
Milwaukee, WI
So would the rear passenger side interior door panel have the little circle insert that covers where the bolt is on the armrest?
I've been looking for one for a while.
WesternMD_VR4
Hagerstown,MD
I'm pretty sure the door panels were complete finding that lil circle piece should be no problem. Might need to start a grocery list for this bad boy.. Most of the interior was there so any interior parts shouldn't be a problem
Fiascoxl
Stuarts Draft, Va
I need the seat belts and corresponding trim!
edit: Nevermind it looks like they are already gone.
Fiascoxl
Stuarts Draft, Va
Would you be willing to pull them for me and grab the A and B pillar trims to go with them? Also I am interested in the 89 under dash panel with pocket too if you don't need it.
WesternMD_VR4
Hagerstown,MD
I'm sure it's all there, if people are interested, I was suppose to go back Saturday for fender but there's a chance of snow so it may not happen, I don't get home from work in time during week, when I go there, I will write a updated list of what's all there and maybe I can move this to the FS section or something
89Mirageman
Stantonsburg, NC
For that fender just remove the bolt with a 10mm head that screws up into the front of the fender (from the edge of the bumper). You may have to push the fender liner out of the way to get to it. Once it's out you can push down on the bumper and get to those hidden bolts that are holding the fender on.
