GVR4 ECU in 93 EGSX?
VR_IV_MR
Queens, NY
I have ECMLink V3 in my galant.
My Eclipse GSX 1993 does not have an Eprom ECU.
Can I put my VR4 ECU with the V3 chip into my GSX?
If I can, won't the mounting points be different?
Note, this GSX is an AUTO trans.
Thank you
You have to swap the cases, not biggie. Auto trans computer is separate from the ecm I believe.
Wizardawd
Franklin, NC
It is. AT computer is sitting on the floor under the ECU and under the shift cables. And yes, 91-94 DSM/GVR4 ECUs are interchangable. 90s can be used as well if you swap a few things.
Wiz
