clutch disengagement issue
gotbl4d3
Active member
billings montana
Ibhave been having issues with my new clutch and tranny my flywheel step heighy is right replaced the pedal assembly and the only thing i can think of is that i have 1g madter cylnder then a gvr4 one are they different thanks
ronkonkoma, ny
Lots of posts on this. Is there a shim on you pivot ball? You sure you bless everything well enough?
ronkonkoma, ny
Did you put a washer behind your pivot ball to shim it?
Where is the clutch fork protrude from your bell housing?
Is it in the center toward the slave cylinder or toward the passenger side?
Is English your first language?
The 1g and GVR4 clutch master cylinders are the same except for the reservoir.
