I picked it up from a member, turbo back. Me: is it for a gvr4? Does it leak? Does it bolt up to a 16g elbow?
Him: yes, no, yes
Honestly nothing against him. I think he did tell me as he knew it.
Well, I got it with dents around the dp (so you could get a socket in to bolt it to the elbow), but there was another piece of pipe added to it before the flange to the elbow that doesn't have any dents. So its very hard to bolt up. Also dents at the rear at the diff and control arm. And a hole that I welded where he states his drive shaft created.
Well, it clears all the later just fine on my car, but I do wonder if my mounts have been modded. The car came with a thermal exhaust that sat at an extreme angle and hit the bumper cover... And the dp sat really low to clear the drive shaft loop. So I picked up this exhaust in hopes that it would bolt right up and allow me to lower my car. Well, up front the only problem is the leak at the elbow and the flex pipe on the pan. it tucked up rather nicely after the dp (up and out of the way so it wouldn't scrape). Out back it doesn't line up with either of the exhaust hangers. (the two in front of the muffler and the one behind). It actually fell off today, but that's my fault because I knew of the problem and didn't weld on custom hangers. But it did exit out the bumper cut out... I think the hangers on my car may have been modded...
