piston ring file
biglady112
Commerce City, Co
A file is fine. A ring filer/grind wheel is ok as well. Just debur the ring after you reach your desired gap.
yeti
san diego california
Sounds good thanks,
Also should each ring in its set measure the same?
If 1 compression ring in a set of 4 is in spec should all the others follow?
biglady112
Commerce City, Co
They should be, but double check them all. And if you are gapping them, it shouldn't matter anyway.
