vr4 brake upgrade
dsmless
tucson,az
have searched and searched but no luck, want to know if theres a write up or someone here has installed 92+ dsm brakes on there galant but kept it 4 lug still??
524of1000
San Antonio, Tx
Our brakes are the larger eclipse brakes. You'd be swapping the same brakes over. From what I've heard, the N/T 3000gt calipers have slightly larger pistons and *should bolt on. The 3000gt VR4 calipers are a sure fire upgrade, but require a 5 lug swap, adapter brackets, calipers, rotors and 17x8 +35 wheels.
Okayplayer
Denver, CO
The 2 piston calipers that our cars come with stock are considered the big big brakes for dsm's. If you want to go bigger, there is the option to use 3000gt/stealth rt brakes which are 4 piston calipers. There is even a kit for it on tunersnation
citymunky
Chesapeake, VA
Quoting 524of1000:
Yes the 3000GT SL front brakes are bigger than OEM Galant VR-4 brakes since 3000Gt was a bigger car. They do bolt-on to hubs with no kit.
Here a set for sale:https://www.galantvr4.org/ubbthreads/showflat.php?Board=UBB1&Number=1040297&page=0&fpart=1
The 3000GT VR-4 had 4 piston front brakes calipers and do adapter brackets (TunersNation), calipers, rotors and rims 17x8 +35 offset or bigger. 5-lug swap is not needed but makes life a bit easier.
dsmless
tucson,az
Thanks this is what i was looking for, theres a 3000gt N/t in the local pullers , thats why I asked
citymunky
Chesapeake, VA
really? The Yard here sucks. nothing cool ever makes it there only Non Turbo 2g's and honda's.
dsmless
tucson,az
Yeah and its all rust free too so no broken or stuck bolts, theres a base model 89 galant here too w manual seatbelts and under dash pocket colors blue tho
makedollarz
Phoenix
I used all the above, 3000gt pads, calipers, and tunersnation adapter plate, and just ordered new rotors drilled for the 4lug galant style. Saved the hassle of 5 lug swap and i already had purchased aftermarket 4 lug wheels, so saved that headache as well, its worth the swap for sure in braking feel.
