engine/car takes forever to heat up
Woosky117
Lacombe, Alberta
hey, i have a 92 mitsubishi galant, fwd, with a dohc engine.
i am having trouble with the car not heating up very quickly at all.
i have many theories as to what the problem might be, but i have no idea it im getting anywhere close with any of them.
i have an aluminum rad, and the engine is jdm. the rad and reservoir are full of coolant.
my theories include the water pump, the thermostat, and that i have an aluminum rad being a problem.
any more ideas? any of those i can eliminate?
it takes anywhere from 15-30 mins to warm up, instead of 5 mins with my 91.
and the oil temperature tends to drop a lot while driving.
your help would be greatly appreciated.
/ubbthreads/images/graemlins/worthy.gif
- Dan
gvr4ever
central Indiana
Bad thermostat or a bad sensor/gauge reporting the wrong temp. I will never buy a thermostat from any parts store ever again. Last one I had lasted all of 6 months and then froze open. I'm just glad I ponied up the extra cash to get the fail safe one to fail open. I'm running a stock temp mitsu one now and quality is way better then the parts stores "best" thermostat.
Woosky117
Lacombe, Alberta
is there any way to eliminate which one it is? or should i just get both?
is there anyway to still buy the stock ones new?
gvr4ever
central Indiana
I would just start with the thermostat. While I'm sure their have been some failures, the gauge is not known to fail. I'm still on my original sensor too.
Mitsu does still have a stock replacement. I'm pretty sure the part number is in the how too archive.
gramkrakr89
Bunker Hill, WV
If your thermostat never fully closes, you can expect a very slow warm-up.
If your dash gauge moves at all, the thermistor it uses is probably just fine. If the engine starts fine and runs fine after warming up (no CEL), and cooling fans turn on once warmed up, your other sensors are most likely just fine as well.
Replacing your thermostat with a good (new) OE or similar quality unit should be the first step.
DDM
Palatine, IL
I can allmost guarantee you that your thermostat is stuck open from what you are describing
IncorpoRatedX
Arizona
plus one for thermostat stuck open.
When i bought 649, the previous owner had put a new thermostat in it the fall prior, in the winter it wouldnt warm up. he swore it couldnt be the thermostat because it was new, i told him many times to pull it regardless (two fuckin bolts) and he instead removed the grill and put cardboard in front of half the radiator to help it warm up. It worked, but driving down the highway it would just cool back down.
The first thing when the weather cooled back down and I noticed it wasnt heating up in 5 minutes of starting it? Pull the thermostat and find that it was bent and stuck open... gee... 5 minutes of work and $7 and functioning heat? WOW!
raptorWagon
Oak Harbor, WA
Quoting gvr4ever:
Never have had a problem with a NAPA or other autoparts store thermostat. /ubbthreads/images/graemlins/dunno.gif
89Mirageman
Stantonsburg, NC
You could also have air in the system. I always fill the radiator slowly with the engine running until the upper hose gets warm. Then put the cap on, cut the engine off and let it sit for about 20 minutes. Make sure the overflow bottle is full and it will pull out what it needs.
Specter
Karachi, Pakistan
I have had the same problem. The car doesnt want to warm up in cold weather. I installed a thermostat and do see improvement, but it takes longer then 5 minutes to warm up. The thermostat had a rating of 72 degree Celicius. So i guess it opens up a bit early.
gvr4ever
central Indiana
Quoting raptorreed:
Quoting gvr4ever:
I wish I hadn't. My NAPA one started opening late and my Advanced Auto Parts one just stayed open or didn't close enough or something. Mitsu one is working perfectly.
