Does a 1g catback fit?
I have been searching the forum for a bit and the answers are all over the place. I want to know if it will bolt right up and fit? I read that you need to make it longer, I read that it does fit, and I read that it is angled different.
What is the reality? My 2.5 inch Buschur just broke at the weld and ripped right of at the tip. Any welder I have ever been too always charges me an arm and a leg and I won't go for that when there are other alternatives.
gtluke
dirty jersey
They don't just bolt right up, but I have a talon exhaust on my galant. You have the move the exhaust hangers. Depending on the exhaust, sometimes the muffler sits all screwy.
My cat-back is a VRS exhaust "kit", meaning it was built without a muffler, and I added my own 18" dynomax to it, which just barely fits.
123abc
Winona, MN
I had to make mine work at the time. We doubled up some rubber hangers, and added a short section at the rear with a ghetto worm clamp to help hold the exhaust. Worked for about a week, then the worm clamp broke. Luckily it broke on my way in to fix it. lol
spooln4fun
Belpre, OH
^ have heard this also.
524of1000
San Antonio, Tx
I used to run this set up. You need a 2g AWD Down pipe, a test pipe or Cat and the 1g AWD Cat back. I *believe* the test pipe has to be 12" or so, but it may be 18". You WILL need to modify the hangers, and even then it will probably rub or bang against something. I honestly recommend getting a GVR4 specific or custom exhaust done.
Brunoboy
San Bruno,CA Home of SFO
my turbo back consist of a 2g awd downpipe, chopped at the flange to accomodate a vband to a all flow cat, mated by vband to a custom catback. from what i know a 2g awd dp will eliminate the cat all together and be long enough to bolt straight to a 1g awd catback to fit.
524of1000
San Antonio, Tx
It won't. You would still have a 12-18" gap. I think it was 12", but that was years ago.
