What kind of turbos can I use with this mainfold
Vr4junkie
Some wack town in CA
Thinking of getting this Mainfold click im thinking of bolting up a Hx35 or hy35 or any other t3 turbo in the price range of no more than $400 that will bolt up to this mainfold and not have any issues with clearance will go civic radiator if I have to
gramkrakr89
Bunker Hill, WV
Had a buddy who tried some T3 manifold for his hx35, and the compressor housing was contacting the block (or something) - had to get it cut and re-welded at a slight angle -
anybody have experience with this particular manifold?
broxma
San Antonio Tx
I think a 35 size turbo hits the block. It's close with a 35r even on my 700.00 DNP tube manifold and I know the mount location of the cast one is closer to the head. The problem can be alleviated by having the turbo mount surface milled at an angle, but you still will need a custom outlet for the hotside to DP connection.
/brox
Vr4junkie
So the Hx35 wont work with this mainfold what about with hy35 ??
Vr4junkie
no the hy35 is a little bit smaller then the Hx35 click
gramkrakr89
Bunker Hill, WV
I see now. The difference in size may be enough to clear the block, as it only took a slight angle for my friend's hx35 to clear. Anybody have experience with the T3 hy35?
