I spent some time looking at Dez's car last night.
Very weird problem.
The car runs about 1400-1500 rpm at cold start up. Then, as the coolant starts flowing, the revs increase slowly until settling near 2000 rpm.
Fuel pressure is 38-39.
Maf (1G) is good. Ecu recognizes (MIL comes on) when it is unplugged, also when it is still plugged in, but not attached to the intake pipe. We also swapped in a known good, same result.
Swapped in a good ecu, but Dez's car has a 1990 board, so the wiring has been swapped, so we couldn't trust the outcome. If it is worth anything, the idle did drop (to about 1100-1400), but was hunting very badly. During this, the throttle open/closed switch was unplugged, and the idle went high (2000-2100) and smoothed out. Plugged back in, idle dropped and hunting again.
Boost leak test proved that there is a sizeable leak between the turbo outlet (j-pipe) and the turbo. The leak is bad enough that we were unable to determine if there are others. Seeing as how this is post-maf, pre-throttle body, it seems as this leak should cause the car to want to die, not idle up.
The ECT wiring is good, don't know about the ECT though. When the ECT gets unplugged, the MIL illuminates.
I don't know if the TPS adjust or base timing is correct, but neither should affect idle this much.
The throttle body is suspect particularly because the BISS port has been filled with silicone. Obviously a problem, but the same TB was in place before the high idle developed. The ISC is likely no good as well, it is an original, not the black plastic one, and most of the 1st rendition units have sh*t the bed by now.
CAS is good. The car runs.
I am stumped.
