New owner of 544/1000
dammitjim
WI
Hi, I picked up #544 the other day. It currently runs and drives and is in overall pretty good condition. The biggest problem right now is that the rear calipers are frozen. If anyone has a good pair please post or send a PM.
Mods list:
16g turbo
1g rods, 2g pistons
Balance shaft delete
Walbro fuel pump
2.5" turbo back exhaust
KYB AGX w/ Ground Control coilovers
Here's a quick pic of the car I took yesterday while working on a few things. I also have a couple questions hopefully you guys can help out with.
1. It's got the CD player, is it possible to swap in the EQ/input instead? I don't need the CD player and would like the aux input to play from an iPod.
2. What is the purpose of the small light above the temp gauge on the cluster?
3. edit: Found the fuse layout click
Neither power mirror works. I don't have a manual or fuse box cover to identify the fuse panel layout. Can someone tell me which fuse is for the mirrors or is there a link that shows the panel layout?
4. (Answered, PM if you have these parts FS) What goes in these empty spots below the steering wheel? Are there trim pieces missing, switches or ?
Okayplayer
Denver, CO
I PM'd you about the rear calipers, I have a set. They whole you are asking about, there is just a filler panel in it's place normally. Same with under the steering wheel. I'll check on the fuse box set up.
KiNgMaRtY
Corona, CA
Welcome. If it's anaftermarket CD player then you can use the aux. If its the stocker, you can use one of those radio transmitters
dammitjim
WI
Quoting KiNgMaRtY:
Isn't there a stock radio option that has an "input"? If there is and it's possible I'd like to lose the CD player and get a stock EQ/input thing.
A71 is sunroof, stock radio (EQ/input)
A72 is sunroof, CD
A81 is CD (no sunroof)
A87 is stock (EQ/input, no sunroof)
dammitjim
WI
Quoting turbowop:
Dude! Did I recently sell you an RC speed control and motor on RCtech? Same username, same state... Small world if so.
Yeah the Castle stuff. It works great, thanks /ubbthreads/images/graemlins/smile.gif
dammitjim
WI
There is no small light above the temp gauge, unless somebody installed one there. People put lights in various places for other aftermarket stuff. For example, I have an LED that lights up whenever my car starts spraying methanol.
dammitjim
WI
This is what I'm looking at.
Anyone have experience with these cluster face stickers? Should I be able to pull that off without trashing the original gauge faces?
Diego
I've never seen such a hole. Going outside just to confirm.
dammitjim
WI
I found this pic on the net, it looks like a peg for the speedometer needle goes there
maroonmetallic
central WI
You are right about the peg for the needle stop.
Also, if those are overlays on your gauges, let me know as I would probably buy them off of you.
Where in Neenah are you?
-Shawn
dammitjim
WI
Hey Shawn, they look like overlays, if I decide to pull them I can hook you up. PM sent about Neenah.
dammitjim
WI
Here's an interior pic of 544. The body and interior are are in great shape for a 20 year old midwest car. 99% of the Hondas from the early 90s around here are complete rust buckets. I'll post more exterior and engine pics when I get a chance to clean it up.
I dunno about the overlays.. I kinda like the classic late 80s early 90s feel of e39a..... I think that kinda takes away a little
dammitjim
WI
Parts!
544 should actually drive normally after this weekend. Right now it's a bouncy, pulling bitch.
dammitjim
WI
Quoting GSXCONVERT:
I'm on the fence about the gauges. I prefer the stock 80/90s look as well, but the white faced pillar gauges look less out of place this way.
