bleeding the clutch
yeti
san diego california
Is everyone else's clutch bleed valve upside down and near impossible to get to without removing something?
Mine points upwards towards the radiator/turbo
OMFGeofffff
Burnsville, MN
Yes. I like to take off the front to rear crossmember to clear up some room. I remember looking at the slave in my buddies 99 GSX and how it looked incredibly easier to get at than with our cars.
Brunoboy
San Bruno,CA Home of SFO
this is true,^ i bled my slave two days ago without removing anything. and ive changed my slave twice and both uninstalled and reinstalled and bled without taking anything else off.
Diego
+1 for never removing a darn thing to change or bleed it. I used a 10mm ratchet wrench too for ease.
Cherry Hill, NJ
it is extremely tight, but i bled mine on the ground in the driveway with a soda bottle, some vacuum hose and a 10mm box wrench. kinda hard but it was easy enough.
I use an old 10mm wrench that I bent at almost a right angle. That way I can still use a clear rubber hose on the bleeder to watch for bubbles and keep everything clean.
xaisomboun
Minnesota
i also found this very hard to bleed but eventually found out a way!
I used a 10mm socket with 2, yes 2 extensions to give enough room to turn. downside is that the fluid might be spilling on the frame part. nothing a little wipe could clean up.
Cherry Hill, NJ
right on terry, bending an old wrench at 90 is such a great idea. i do this often enough to want a 10mm bent, i also use a clear hose to see the bubbles... new to posting on forums, never really done it before i i have to realize i need to be a little more detailed.
