Check engine light doesn't light up
OMFGeofffff
Burnsville, MN
So I was driving to work today and I lost power to my engine. I can crank and crank but it won't fire. I noticed that my CEL doesn't light up when I turn my key to the ON position. Luckily I still haven't put my ecu back up into its spot so I unplugged it and opened it up. Visually everything looks good still since I've had it rebuilt last yaer. Is there anything else that can cause the cel to not light up when turning the key to ON? Anyone in MN have a spare stock emprom chip they can give me or borrow? I'm hoping my dsmlink chip didn't fry or something.
Also I heard a relay click a couple times shortly after it died.
MellowVR4
Milwaukee, Wi
possible that the bulb burned out or someone had the car before you and noticed that light was on and disconnected it lol.
OMFGeofffff
Burnsville, MN
It worked before. It stopped when my car died while driving. Now the cel doesn't light up and it just cranks but doesn't start. I'm just seeing if there's anything not related to the ecu that cold cause this.
Dark_Horse
Morrison, CO
If the CEL doesn't come on and the boost gauge doesn't move 1/2 way when the key is in the ON position - it's most likely ECU related. I can't think of any other reason why the CEL wouldn't come on besides ECU problems.
yeti
san diego california
Your CEL is supposed light up for a few seconds then shut off and your boost gauge is supposed to light up half way
If any of these are not present then your ecu is bad or at least a part of it is.
Also Make sure your eprom chip is fully installedf
tayschells13
I have the same problem, except my car starts and runs fine. I'm thinking maybe I just came across a rare occasion where my bulb actually burnt out, or maybe I have problems stirring up /ubbthreads/images/graemlins/uhh.gif
OMFGeofffff
Burnsville, MN
It was the ecu. Threw a working one in and fired up. At first it looked like the ecu was fine but upon closer inspection there is a small burn spot that might of been the culprit. Now to get a hold of terry to see if he can fix it again.
Cherry Hill, NJ
i have an ecu out of a 92 laser rs awd non-eprom, would you want that for 75 shipped?? i could pull the one in my vr4 out and test it first to make sure it works for ya.
OMFGeofffff
Burnsville, MN
Already bought an eprom. I figure I'll get caps replaced and have it socketed once I get my old one fixed. I'll actually keep it as a spare too instead of selling it like I did with my last one.
