What is this wire for?
asmo
SLC, Ut
fuel pressure solenoid
KiNgMaRtY
Corona, CA
Where does it need to be hooked up too? (Where in the engine bay)It is on the passenger side of the car.
asmo
SLC, Ut
is it on the same harness as the mas air sensor, theres two plugs on there, ones for the fuel solenoid, ones for the boost solinoid, both look the same. I think it need to be pluged in even if your not running vacuum lines to it.
KiNgMaRtY
Corona, CA
Thank you for the diagram. I'll check again tonight.
The wire does come out of the Mas harness or around it. The redish looking wire is actually orange. I saw there were two others that were plugged in with vacuum hoses coming out from them. I looked around to see where this particular one would plug into and couldn't locate it.
BPU925
katy, tx
if its around the mas its most likely the one for boost solenoid....
spooling92vr4
long island, NY
its in the back left of the engine bay, next to the washer bottle, do your squirters work? looks like the plug for the washer fluid motor.
