Boomba Throttle Body
onesickcrx
NY
Any one have any experence or info with this throttle body? I would think it was pretty good since AMS is selling it. I have a 63mm big bore oem rebuilt one now I just would like to be able to flow some more air into my drag intake manifold.... Boomba Throttle body
Man if you want air flow hit ebay and search for a few factory ones 90mm Q-45 or a Lightning oval or the early mark VIII oval with the 4.6 it has a progressive dual butterfly. Both ovals equal to around 80mm. I have all three in the shop but haven't decided on which I'll use yet. All run on a 5 volt TPS signal.
I'm going to be running megaspit on mine so the idle stuff isn't a big concern but any throttle body can have the lower section of a DSM TB welded on and opened up inside to reference airflow before and after the blade.
onesickcrx
NY
I am not looking for something huge like a Q45 thottle body just something bigger then stock
Any other info on the boomba?
