-10 AN Breather oil cap
Near Seattle, Washington
I'm reposting this from the AG Postwhore thread, since at least one person has expressed interest. Hal says these are no secret, just not discussed a whole lot. He was actually interested in where i'd heard of them. I spotted them in some random image somewhere, and tracked down where they came from. I've asked him if i can share his contact information, for those of you not members of the link forum.
I ordered the cap. Hal already had some made up and ready to ship.
If you're on the dsmlink forums, you can look up Hal Landry. He sells them. I do not know how many he has made at the moment, but he will make them as needed, i suppose. You can try emailing him as well.
Quoting Hal:
Billet aluminum oil filler caps
Fits 1g, 2g, and Evo
CNC machined from billet 7075 aluminum and polished to a satin finished.
Each cap has a single -10 male A/N fitting installed in a manner that permits
orientation in 90 degree increments.
$80 shipped (USA only) or $75 local pick up.
Quoting Hal Landry:
I can be reached at [email protected]
Hal's a good guy and has been around 4g63s for a long time.
He will probably want to provide you some instructions on use of this cap before you decide to order, so that you know what you're getting into. These do not come as a complete "kit". I'll be ordering a JMF Deluxe catch can with -10 AN fittings on it for my setup.
JNR
ca
Ouch ($), but nice looking.
So, does this replace the nipple used for the PCV (not the valve, but the recirc where you run the catch can from), or does it supplement scavenging?
I do need a new oil cap and now I want to make one on the lathe, damn you! (although not sure about the breather part of it, as far as being effective?)
PS - what is that hole on the top for, the attachment screw to the "arms"?
Quoting oil cap instructions:
Warning! Severe personal injury may occur if proper precautions are not used when handling this part!
This part is intended to vent excess crankcase pressure. Because of it’s location the baffle is exposed to a large amount of oil splash. Consequently the baffle can become saturated during periods of high crankcase pressure. For best results your catch can must drain back to the block. The most common location for this is the balance shaft inspection hole in the back of the block.
If you do not have this type of installation, you can use the following parts list to connect your catch can drain to the engine block using -4 hose. Because each can is different, the hose length and fittings used to connect it to the can will be different.
Earl's 977515ERL 10mmx1.25mm banjo bolt
Earl's 997641ERL -4 to 10mm banjo
This part is intended to supplement the oem crankcase pressure ventilation system. It should be used in conjunction with the oem vent nipple found on the valve cover. If you intend to use this as your only source of pressure relief, you are wasting the excellent oem valve cover baffle design and putting more oil thru the catch can system than you need to.
This cap gets extremely hot. Failure to use proper safety precautions can result in severe burns! Never touch or grasp this part without using gloves or some other form of protection to prevent personal injury.
1) Verify that you have adequate clearance between the hood and this piece under ALL conditions. Aftermarket hoods, worn/broken roll stops, pneumatic hood supports, and host of other factors can influence the amount of space between the valve cover and the under side of the hood. Failure to properly verify clearance can lead to damage of the hood, your new cap, or even the valve cover itself. This is especially critical for those people with 2.4 liter conversions because the 2.4 block is 6mm taller than the 2.0 block. This puts the cap 6mm closer to the hood!
a. You can detect clearance issues before you install the cap by setting up a simple test. Create a tube out of tin foil. The foil should be doubled over so it has more rigidity. Tape the tube around the oem oil cap in such a manner that it will remain in place. Measure from the valve cover at the 9 o’clock position (1g/2g DSM with oem engine orientation). Trim the tube so that it is 1.5” tall when measured from the valve cover. Take the car to the track and have at it. Inspect the tin foil for indications that it is hitting something. If there are no observed clearance issues, then you should be good to go ahead with the installation. If there are issues, resolve them before installing the cap! After installation, occasionally inspect the top of the cap for signs that it has started to make contact with the hood. Roll stops wear over time and motor movement will gradually increase.
2) The cap is locked down with a spring clip and -10 hoses are stiff. They can act as a lever and force the cap to no longer sit flush with the valve cover. When this happens you’ll wind up with a nice coating of oil on your valve cover. To prevent this, -10 hoses must be properly supported so they do not impart unwanted force on the cap. You may have to tie the hoses off against some form of bracket and/or relocate your catch can.
3) You will notice that your new cap is not fully assembled. You will need to transfer the lock spring, gasket, and retaining nut from your old cap to the new one. To do so:
a. Using a Phillips screw driver and a 6mm wrench (or socket), remove the nut from the screw. The oem screw has been staked so it may take a bit of effort to remove the nut.
b. Lift the lock spring off and remove the gasket. If your gasket is hardened from age, it can be replaced with Mitsubishi part number MD103148.
c. These are all of the parts you need to re-use. Put the OEM cap and the screw you removed from it into a zip-loc bag and set it aside in case you wish to put the oem cap back on.
d. Your new cap comes with some foam type material inserted in it. DO NOT REMOVE it. This is the oil baffle!
e. The cap was supplied with a new stainless steel screw, splash shield, and washer which, when combined with the gasket, lock spring, and nut that you removed from your oem cap, will result in a fully assembled part.
f. Place the gasket from your oem cap onto the new cap. Note that one side is ribbed. Orient the gasket so that the ribbed side will contact the valve cover when the cap is installed.
g. Place the lock spring on the square shaped post in the center of the cap. The spring will lock the baffle support into place. If your cap has more than one hose fitting there will be a marking on the cap underside to aid you in the proper orientation of the lock spring.
h. Place the round splash shield above the square shaped post in the center of the cap.
i. Insert the screw thru the cap and install only the nut. As you tighten the nut the splash shield will form itself to the underside of the cap. Now remove the screw and nut then place the washer on the splash shield.
j. Place some thread locker on the threads of the supplied screw and insert it into the cap so that it protrudes thru the lock spring, washer, and splash shield.
k. Thread the nut onto the screw and tighten securely. Failure to properly secure the nut will result in the nut, splash shield and lock spring dropping into the valve train of your engine. The oem screw is staked. It is highly recommended that you stake the threads on the supplied screw!
l. Visually inspect the lock spring to ensure that it is fully seated on the mounting post.
m. Install the cap on to the valve cover. It should fit snugly just like the oem cap. If it does not, stop here and figure out why. If you determine the cap appears to be faulty, contact me.
n. Install the breather lines, making sure they are properly routed. For best results, the inlet fittings on the catch can should be higher than the fitting on the cap. Make sure the lines do not rub on anything. Prolonged abrasive action will damage the line and/or what ever it is rubbing against. Do not apply more than 5 foot pounds of torque to the hose fittings on the cap. They are bonded in place. These are breather lines and as such do not require more than a slight snug to achieve a reliable, leak free seal.
This cap is designed to be installed using an OEM oil cap gasket and lock spring. The use of non-oem parts may have on effect on how well this cap seals against the valve cover.
This piece is a custom made part. It is intended for vehicles which are never to be operated on public roadways. The use of this piece may be in violation of both state and federal vehicle emissions laws.
This piece is backed by a 100% money back guarantee. If you find that it is defective or flat out does not work like expected, the original purchaser can return it for a complete refund of the original purchase price. No questions asked. Shipping costs are not refundable.
Disclaimer of warranty
Consequential Damages and Limited Liability
This warranty does not cover consequential damages, and the liability of the seller is limited to repairing or replacing the oil filler cap in accordance with the stipulations contained in this warranty. No other warranty, express or implied, is made.
Thread about the caps.
There are some threads on another forum as well, where people are discussing use of this cap. Apparently it helps a GREAT DEAL on crankcase pressure evacuation. There's a thread or two over on evolutionm, where someone is claiming that they gained dyno HP and pulled better ETs with no other mods. Not sure how true it all is, but it's a well documented fact that too much crankcase pressure is a detriment to performance.
Street Surgeon
Omaha, Nebraska
Ever seen a valvecover with an fittings welded on? Now you don't need em welded in place. I guess one of the benefits would be that to PROPERLY add an fittings to your valvecover you would have to have the baffles removed, the valvecover modified, the baffle replaced, and then the valvecover powdercoated. In my case I just am having the ports welded shut, and running this -10an cap over to a catchcan, and then to the intake pipe.
EDIT>> The hole on the top of the cap is where the screw goes through for the restraint/arms on the underside of the cap. I can take a few pics of mine when I go home if anyone is interested. Just make sure you stake your screw and the nut in place after you install the hardware to prevent it from backing off and falling into your valvecover.
Street Surgeon
Omaha, Nebraska
Just make sure you clarify what direction you want the an fitting to point! I personally have mine shooting towards the firewall and from there can run braided ss line over to a catchcan near the passenger side of the firewall. That's just how I ordered mine though.
I wouldn't stainless braided line off that cap anyhow, having read what i have read. It's just too stiff and unmanageable. I'm not a fan of the metal lines, because they scratch things, and are just a pain to deal with.
I've already got my Russell ProClassic oil cooler and fuel delivery lines. I'll be getting the same for my breather setup. The only place i'll be running the stainless is turbo oil feed/return.
EDIT: Hal says the outlet is able to be pointed where you want in 90° increments. Maybe previously it was only 180° increments, like the factory oil cap. /ubbthreads/images/graemlins/dunno.gif
JNR
ca
Couldn't you just loosen the "arms", orientate as desired, then tighten? It does seem like it would be a PITA to loosen/remove the oil cap with a line coming off it /ubbthreads/images/graemlins/confused.gif Edit - looking at the pics, seems like a fixed assembly. What would be trick is to make a two-piece cap where the top pops off (with the hose attached) and the bottom unscrews and can be removed...
belize1334
Bozeman, MT
I would assume that the under-side of the cap is indexed so that the arms sit securely in place and don't try to rotate.
beaner
b'ham, mi
What's up with the installed pic? The nipple on the side is unused but this cap was needed?
^ no, it was not completely put together when the photo was taken.
The owner stated he fully intended to utilize that nipple.
I was thinking, I may put a little baffle of my own, under the oil cap. Maybe a piece of sheet metal that bolts down with the cam cap bolts... it would keep oil from hitting the cap due to windage, much like many other cars have under the oil cap.
Street Surgeon
Omaha, Nebraska
The cap has a lil' baffle on the bottom, but it's nothing that would prevent the bottom of the cap itself from being hit with stray oil. The SS line off it is not biggie it works fine, and if you have the lil' rubber/silicone clamps to keep it in place then there's no fuss. That being said sure, you can run whatever ya like from it (pushlok, nylon, regular line etc.)
Someone reported that too much stress on the stainless line put the cap off-kilter, and caused it to leak.
I realize there is some kind of baffle in the cap, but i was thinking it may be prudent to put something on top of the cam towers, just to avoid that much more oil entering the ventilation system.
All i think would be necessary would be a rag. I don't think it'd be any hotter than a greddy or other aluminum oil cap.
onesickcrx
NY
I think its a great way to vent the motor for cheap and quick install which is always nice... But I think at about 400+HP I think you would be better off suited with 2 -8an or -10an breather hoses so what do you do then? weld on another oil cap /ubbthreads/images/graemlins/dunno.gif /ubbthreads/images/graemlins/smirk.gif
