2 step vs anti-lag (video)
4thStroke
Vancouver, WA
2 step at 5500RPM, anti-lag comes on at 5000RPM. Timing set to 10.1 degrees ATDC, fuel enrichment at 5%. 10psi with the 2 step, 20psi with the anti-lag.
Enjoy.
Nartanian
Richfield, MN
/ubbthreads/images/graemlins/applause.gif Now hurry up and start breakin stuff!
raptorWagon
Oak Harbor, WA
Spencer has already done that, he's trying not to break stuff so quickly right now. Drivetrain components get expensive real quick /ubbthreads/images/graemlins/wink.gif.
AnotherNewb
Orlando, FL
/ubbthreads/images/graemlins/grin.gif I like breaking stuff
4thStroke
Vancouver, WA
I enjoy it, too. But I don't enjoy pullin the wallet out for repairs.
The 20psi launch has been tempting, I just don;t think the stock center diff would take it too well. Maybe just once. /ubbthreads/images/graemlins/hsugh.gif
1qkfwd
Sun Valley, NV
Try using a higher timing. On my 40r I have the ALS set for 6750 with 20 degrees timing no fuel enrichment. I leave the line between 25-28 lbs. It's less violent on the exhaust wheel. Withou ALS I was only able to get 14lbs no mater how long I sat on the 2-step.
1qkfwd
Sun Valley, NV
20* atdc. And I'm gonna guess the op is using link since 10.1 adtc is the default setting.
1qkfwd
Sun Valley, NV
It will be less aggressive the higher you run the timing. You can probably get your 20lbs with the timing up more and it won't be as harsh. I had to mess with it a lil bit to get it how I wanted it.
4thStroke
Vancouver, WA
Maybe I'll see if I can get it set up so I'm launching with an open wastegate, 25psi. /ubbthreads/images/graemlins/devil.gif
Brianawd
Portland OR,
Antilag on street tires just turnes them to smoke.
4thStroke
Vancouver, WA
No way Brian, worn Goodyear Eagle GTs are going to hook like a mother on pavement, I have AWD. /ubbthreads/images/graemlins/dunno.gif
