17x7 +47?
17x7 +47
what do you guys think about the offset? i know stock is +46. i looked at the wheel fitment guide and didnt see this wheel size there. im sure it will fit but wanted to get some opinions of the offset. ideally i would have preferred a much more aggressive offset but the wheels i plan on getting are old and discontinued. its also at a great price but i wont be able to test fit them.
thanks.
H05TYL
Wgtn, NZ
I think they should fit, unless your running wide tires on the 7" rim.
however they will sit in quite a lot at the rear (especially if it's lowered) and may look a little awkward.
I'm running 17x7's with a +32 offset and some 5mm spacers I had lying around (so effectively +27 offset) and they STILL aren't quite flush with the guards at the rear (car is lowered 30mm or so).
If the wheels are hard to find, and your getting them cheap, i'd take the risk and buy them - you can always sell them if they don't fit/look crap - possibly for a profit too.
^ thanks for the input
may i see pics of your car with the aforementioned wheels?
That is about as pizza cutter fwd size as you could get. I'd hold out until you could get a better offset.
H05TYL
Wgtn, NZ
This is the best pic I have on this computer, the wheels your looking at will sit about an inch further in than these.
and here's a pic on my other one, which is much lower
2of9
IGH, MN
that's exactly the rim offset I had on the galant for a day. I shoud have taken pictures! /ubbthreads/images/graemlins/banghead.gif oh well. The fit perfectly on stock suspension and will not rub. i also ran 225/45/17 Dunlop Direzza DZ101 tires also. The rims will stick out a bit though....If i remember correctly, it's almost about half an inch.
2of9 are you referring to the wheel specs of H05STYL or the one i mentioned?
whats the most aggressive wheel spec you guys have seen without having negative camber? (new topic/thread?)
staggered setup?
these are the wheels i was referring to... just wish it had a better offset.
old school Work Mesh wheels...
H05TYL
Wgtn, NZ
nice wheels! *jealous*
are they 2 or 3 piece? if they are 3 piece you can replace just the outer part of the rim quite cheaply with an extra inch and a half of lip giving you an 8.5 +28 wheel.
depending how much width you add at the lip you could end up with:
8" +34
9" +21
10" +9
firstly though, check there is enough room for the 148mm backspace these rims have (from the hub face in towards the strut in the front, and the trailing arm in the rear).
2of9
IGH, MN
Quoting jayb0i:
staggered setup?
Sorry, I was referring to your specs. Those rims are pretty cool looking though.
here were the rims I had before selling them. they were +47 offset. stuck out just a bit on me.
Quoting H05TYL:
8" +34
9" +21
10" +9
ohhhh nice. i'll have to find out on the wheels. THANKS
