Splurged on a DSS driveshaft
BlitzVR4
Virginia Beach, VA
Was too lazy to rebuild my drive shaft so I ordered one from DSS yesterday. Look what the UPS man dropped off. Real pretty.
Nartanian
Richfield, MN
looks real good! How much was it?
JNR
ca
Looks nice! Does it connect to part of the factory shaft, or is there another piece?
14u2nV
Agency/St. Joe, MO
^^looks to me that the circle piece in the bottom corner hooks to the d/s on one side and takes the place of the lobro on the other.
JNR
ca
Just looks like the bolt pattern is larger on the aluminum (?) circle...and are there studs on the backside to accept the new DS...maybe I'm missing something; just wondering.
BlitzVR4
Virginia Beach, VA
The driveshaft actually has an adapter which attaches to the lobro joint. I took a better pic of where it would attach to. Paid 799 plus shipping. It weighs 15 lbs.
14u2nV
Agency/St. Joe, MO
It looks good, but why spend $800 on something that really isn't going to affect performance? When people are running stock d/s's and making big power, what is the benefit of having this? A complete rebuild on a stocker is around $150ish~. Is there a real reason you bought it, or just a bling factor type thing?
2of9
IGH, MN
nice. I wouldnt mind getting one just because of the BALLA factor! lol. great purchase indeed though. I think putting these kinds of "mods" in your car will surely raise the price of it.
14u2nV
Agency/St. Joe, MO
Brianawd
Portland OR,
Big reason for going to the aluminum shaft is to help with drive train shock. Steel does not twist as much as aluminum. So with the aluminum shaft there is less shock placed on the drive train because the shaft is twisting. The shaft then springs back. It also a lot lighter. Stock first two steel parts are around 22lbs. The aluminum is around 12lbs
BlitzVR4
Virginia Beach, VA
Quoting 14u2nV:
When I totalled the price of rebuilding the stocker take in account new carrier bearings and all the parts that need replacing and the time it takes to do the project. For me it was more of a convienent purchase. Yeah and also the bling factor.
I really don't have the time. My weekends are filled with projects. We just purchase a new home and doing things around the house takes up so much time.
1941Galant
Charles Town, WV
Rebuilding the stock driveshaft is kind of a pain in the ass, especially when the U-joints don't easily come apart. I think Jeremy (GVR4ZUM) and I spent a good 10 hours rebuilding his last summer, it was our first time though. That Al. shaft looks like a nice peice, I may go that route once I am done with school.
gtluke
dirty jersey
steel twists more than aluminum. aluminum has no flex, which is why your springs are always made out of steel.
the reason for the shaft is to reduce rotational weight. it works the same way as an aluminum flywheel. it also saves considerable weight off the car.
vapid
IL
Blitz-
They probably sent you the one they made for me to replace the 2 wrong ones they sent me so far.
Hopefully 3rd times a charm.
JNR
ca
I wouldn't say aluminum has 'no' flex, but when it does, you risk the material cracking. However, being it's a cylinder, it's doubtful. I think the weak link is (and should be) the u-joints, although better have a loop should the shaft come off in front (yikes).
Nice looking piece. A little pricey, of course, but once you factor in the time, sometimes it's worth paying up front. Just curious why they didn't also make the front piece, but it's good to eliminate one of the flex points.
Myles
Skokie, IL
Quoting 14u2nV:
From who? A new Lobro Joint alone is $200+, Carriers $65~ each, U-joints 40 each.
/ubbthreads/images/graemlins/dunno.gif
14u2nV
Agency/St. Joe, MO
You don't have to replace the lobro, when I pulled mine apart I saw no signs of wear. Rebuilding mine, with wire-wheeling/coating and everything else will be well under 10hrs total.
Mark
Naperville, IL
A lighter driveshaft will also help w/the weight off rotating mass.. I got one on my galant also. Have had 0 problems with it.
