Turbo Bolts
Anyone have the part number for the turbo bolts that attach the turbo to the exhaust manifold? The stud snapped when I was removing the turbo and I figured the best fix would be to replace it with a bolt instead. I lost my version of CAPS so i can't look it up.
jepherz
KC, Missouri
From the part number archive in the how-to section:
Turbo->Manifold Bolts - MD132656 - $5.50 - $5.63
You should try and get the 2G bolts/washers, and I'm not sure if that's the correct bolt or not.
I'm drawing a blank. What is the advantage of the 2g bolts over the 1g? I swear after a couple years out of the scene I've forgotten everything I knew...
Struc
Oconomowoc, WI
solidviper89
Mission/ San Antonio, Texas
I had a bad experience with the ARP bolts. Now the car is JSB.
IMHO the ARP bolts are usless for me. Im using the 20yr old stockers.
Just in case anyone is wondering, last summer I installed the turbo with new gaskets and ended up having an exhaust leak, so when trying to fix the exhaust leak I snapped both ARP's off and they are seized in there good. I used Copper anti-seize so that it wouldn't happen but it did anyway.
I thought the 1g/2g bolts were the same? /ubbthreads/images/graemlins/dunno.gif The 2g washers are the better cone style that lock together when tightened down. Definitely get those.
Dan D
Brownsburg, IN
Bolts are the same. Washers are different. 2G double cone washers, OEM bolts, and nickle antiseize. I haven't broken a bolt since the first time I took things apart (10 yrs ago).
mikus
Aurora IL
same here, broke 4 of 4 ARP's on a turbo that had less than 10K since installed
jepherz
KC, Missouri
Quoting turbowop:
Ahh good call. Maybe I'm just thinking that 2g's come with 4 bolts instead of 3? (if they even do).
In any case, I second the use of the 2g washers.
Struc
Oconomowoc, WI
Ok then... Stock it is.
2G Bolts: MR187699
2G Washers: MR187848 (2 on each, total of 8)
