Your Valve Cover Paintjobs?
Chim55117
Little Canada, Minnesota, United States
Meh. The valve cover on my VR-4 was red, nasty, and coated with six layers of paint, and I couldn't stand it. So I bought a valve cover from Nate Crisman and sandblasted it and then proceeded to airbrush it with Duplicolor Semi-Gloss high heat engine enamel. It looks pretty good in my opinion, despite the fact that the areas where the letters were shaved off are not totally smooth.
The valve cover is just being placed over the one on sixsixtwo's VR-4 for mockup because I'm not going to my VR-4 until later this weekend or so.
Anyhow, comment on my valve cover, or post your own pictures of yours!
3rdstrikedsm
32159, FL
You never wan't to sandblast a vc because you can't get all the sand out of the baffels and it will ruin your turbo and maybe your engine over time /ubbthreads/images/graemlins/frown.gif but here is how mine turned out, Kind of like yours.
TylerAdamson
Iowa City, Iowa
Doesn't matter how well you mask off the underside of the valve cover, somehow blasting material always ends up under the baffles. The only way to get the media out is to remove the baffle, clean, and then re-weld the baffle back on.
Near Seattle, Washington
I think i'm going to blast mine, but if i do, i intend to bolt it to a spare head with all gaskets in place before doing so. /ubbthreads/images/graemlins/grin.gif
I'm relatively certain this would ensure no media gets into the VC baffles.
pachood_1953
eau claire, wi
^^ I believe thats how the JNZ finishing guys said they do it.
I have a spare JUNK head laying around, and a couple vc's, and I just got into powdercoating.
Time to get busy.
Brianawd
Portland OR,
fivestardsm
Middle, Michigan
Quoting mitsuturbo:
That is how I did mine. /ubbthreads/images/graemlins/smile.gif
524of1000
San Antonio, Tx
heres mine so far...
Its powdercoated black wrinkle w/ polished letters and the red diamond stat /ubbthreads/images/graemlins/smile.gif
I like the crinkle coat. My buddy did it to his oil pan. It holds up pretty well.
CarRacer
Shakopee, MN
524of1000: I really like the allen head bolts you used. It makes it look a lot nicer. You just have to be careful to not over tighten, it could be easier to do with an allen wrench.
mikus
Aurora IL
not the best angle for VC but you get the idea
3rdstrikedsm
32159, FL
Quoting chim55117:
Wait, allow me to correct your misconceptions. I masked off the valve cover. The bottom of the valve cover is completely clean.
It does not matter how clean it is and I would be willing to bet there is media in the baffles, That sand fover at 150mph so take is not going to do much to stop it from finding it's way in.
I wish someone would have told me this before I lost a turbo because of it and eventually lost my lower end. /ubbthreads/images/graemlins/frown.gif
Keep in mind the cover itself is a charcoal color, and the lettering matched the car color, bark metallic blue..the pic was an attempt to be artsy craftsy.. I did manage to spend a great deal of time cleaning up bad cast marks and customizing it
FCR
Orlando, FL
My color is from toyota tacoma xrunner (electric blue)
Quoting 3rdstrikedsm:
Quoting chim55117:
I bead-blasted/powdercoated my valve cover over six years ago. I guess I got all the media out since I'm still running strong? /ubbthreads/images/graemlins/hsugh.gif
You can clean all the crap out, and if you mask it off well enough it'll do a good job of keeping the crap out.
Here's mine:
