Need part numbers, Rear subframe bolts etc. CAPS help please
Hey everyone,
I am currently undergoing a restoration on my VR-4 and need some help with part numbers/places to buy the rear end bolts and misc hardware undercar.
Things I need:
-All rear subframe bolts, basically every bolt associated with the rear end. (ie. Mounting bolts, diff bolts, control arm bolts, trailing arm bolts etc.)
-The "triangle" mounting studs that bolt to the chassis via 3 bolts to hold the rear.
-Driveshaft carrier bearings, u joints, nuts to mount it
-Brake line/fuel line little brackets that mount the long brake/fuel hardlines running underneath the car
-Front subframe bolts, control arm bolts etc.
-Front/rear sway bar endlinks
Basically I am looking for screen shots or just part numbers for everything underneath the car if possible.
If you can help me out or send me in the right direction, I would greatly appreciate it. I've been looking on JNZtuning's website and have found some, but figured this might be easiest. Thanks in advance.
Struc
Oconomowoc, WI
You ever think of just downloading CAPS?
Yes I have, do you have a link for the download? I was under the impression that it couldn't be had for free? Any pointers would be appreciated. Also I am using a Mac computer if that helps, I've only found ones for windows.
Spyke169
Greenfield, Wi
I was going to mail you the copy I got off my work computer, but this may be easier.
There you go Raatz, not sure if you need a name and password, but I sent you a pm with mine if you do
