Pulling to the right
The_Big_Weave
Rapid City, SD
When it snows hard the galant pulls to the right when I slow down, well more of like a jerk to the right. It never happens when i am on the throttle, only when I am slowing down and get below 25mph. Also I have a really Bad CV on that side if that could be part of the problem. Would be greatful for any help.
Jerking to any direction while braking is a brake issue.
More than likely the caliper pins are hanging up not letting the caliper float.
Dust boots ripped is most likely the culprit.
The bolt/pins are sealed inside rubber boots to keep them floating.
Take the front brakes apart and you will see what I am talking about. When you put everything back, clean everything really well and use a little grease on the bolts.
If the caliper is binding up, it will be intermittent. Here is the breakdown of the brakes.
91GSR
Newport News, VA
just for that pic this almost belongs in how to. i will most definitely be using that soon. my front brakes are acting funny as well.
