313/1000 Build Thread - New to the GalantVR4.org Family
Chim55117
Little Canada, Minnesota, United States
Hey guys, I'm dc_style and sixsixtwo's little brother. I'm currently 16, and I am in the process of paying dc_style off for 313/1000, which used to be kevbo6204's VR-4. Plans are just to fix the body damage right now, and pay off the car. But anyhow, I thought it would be nice to introduce myself. For the Minnesota guys, I guess this means I'll be the youngest guy at the meet this year? I expect I have a lot to learn from you older guys on the forum!
- Stephen
Pictures from kevbo6204's sale thread:
Specs from Kevbo's thread, with TO BE ADDED as things needed to be replaced or going to be installed soon.
ENGINE:
· Forged 8.3:1 Wiseco Pistons
· Bored .020
· Cometic MLS Head Gasket
· Reconditioned Stock Rods
· ARP Head Studs
· Lightly Ported Head
· Reconditioned Head (New Springs, Guides, Valve Job, etc)
· New Front Case (Oil Pump)
· Balance Shafts Removed
· Rebuilt 14B Turbo
· All New Bearings and Gaskets
· All New Timing Components
· Brand New Alternator (1/15/09)
· Brand New NAPA Water Pump (3/20/09) - TO BE ADDED
PERFORMANCE:
· 1G Shifter
· Gasket Matched 1G Intake
· Gasket Matched 2G Exhaust Manifold
· Ported Turbine Housing and EVO 3 O2 Housing
· Custom 3” Turbo Back Exhaust with Magnaflow Muffler
· Boost, Oil Temperature, and Oil Pressure Auto Meter Gauges
Mounted in Dash
· Rewired Fuel Pump
· Rear Mounted Battery with Summit Racing Box
· Keydiver Stage III Chip
· Freshly Cleaned and Flowmatched 560CC EVO 8 Injectors
· 3G Mass Air Flow Sensor with Brand New KN Filter
REPLACED:
· Valve Cover Gasket
· All Radiator Hoses Replaced
· Throttle Body Cleaned and Seals Replaced
· Front Ball Joints
· Power Steering Pump and Rack
· Rear Brake Calipers and Brake Pads Around 140K
· All 4 Brake Rotors
· Parking Brake Cables
· Clutch Master Cylinder and Slave Cylinder
· Tires (Fuzion HRi) at 150K
SUSPENSION:
· 4WS Disabled - Equipped with Non 4WS Rack
· KYB GR2 Struts
· EVO VIII Suspension - TO BE ADDED
MISC:
· Kenwood Audio Deck
· Pioneer Speakers
· AC Disabled
· Thule Rack
Build/Repair Progress:
3/16/09
Went to the junkyard and found some nice condition 89' headlights to replace the ones damaged in the accident, picked up a pair of corner lights as well, and the piece that goes directly above the bumper.
3/20/09
The water pump broke and the accessory belt snapped. I have to have the water pump replaced in order to drive it. Painted a USDM grille from the garage to replace the broken grille currently on the car. Painted it by prepping it with 1000 grit sandpaper and denatured alcohol and then 2 coats of Duplicolor Primer Sealer, 3 coats Duplicolor gloss black enamel, and 1 coat Duplicolor clear coat.
streetmasters
NYC
Looks like you are on your way /ubbthreads/images/graemlins/applause.gif
Welcome and good luck!
Boostin21
Wisconsin, USA
glad to see your fixing it asap... that was my old car and i miss it very much. keep us updated on the progress.
Nartanian
Richfield, MN
Quoting chim55117:
- Stephen
Welcome!! dc_style is a great guy!! Don't worry lol I'm not that much older than you.
