Lonewolf64
So I took 889 to the dyno for the first time ever. It's basically an Evo3 16g + all the boltons setup. The pull was done on pump gas, but unfortunately I had a slight issue with boost creep and had knock up top and timing pulled.
The tune is just a keydiver chip with no further fuel corrections. Once tuned and boost creep issue is solved, I should be making a lot more power. Now on to the pictures!
The result: 326 awhp, 310 ft/lbs torque
Notice I lose power completely after 6,000 rpm. I have a slight boost creep issue which caused knock and pulled timing. I hope to see better results once this problem is fully addressed.
