Who is enterested in dimming LED gauges or any LEDs
I am having my cousin (owner of Digital Delay Electronics) making a PWM (pulse width modulation) device for my car. This device will be a very simple unit that will have:
__________________________________________________________________________________________
A wire to be hooked to a dash light source (stock dimming bulb wiring) for a trigger
A wire for fixed 1/2 brightness for people that want to have then on all the time but not so bright
Wires hooked to +12 and ground
A wire to be hooked to the LED device
The "trigger" wire will be set for voltage of 8.5 to 12 volts (stock GVR4 voltage) to allow very dim to full brightness for true look and feel. Just like the dash lighting.
The unit should be about 2" square X 1/2" tall and protected by heat-shrink tubing to keep the cost down and about 12" of wire each sticking out the end for hooking up.
This should work with ANY LED product (e.i. - gauges, dash back-lighting, floor lighting, dome lighting)
The cost should be around $35 +/-$10. I can nail this cost down as it gets closer to finishing my unit (hopefully this coming weekend I should have a working unit in my car).
How many would be interested? If enough are wanting these, I can have a PCB made but if only a few are, I will make them out of "bread board".
mistaVR4
Boulder, CO
Sounds pretty cool Terry! I would be very interested pending the results of the unit your having made...
maroonmetallic
central WI
Im interested.. as long as I don't get charged twice for it.
-Shawn
For you Shawn, I will only charge you once but it will be at 300%. /ubbthreads/images/graemlins/rofl.gif
1 small change and it is a much better idea than mine.
Instead of a circuit that dims AND a fixed circuit. It will have just 1 circuit. That circuit will have a brightness control that you can set you maximum brightness when you have the dimmer control all the way up. Then it will dim as you lower the dimmer.
Basicly for those that don't want the gauge to be full bright with the dash full bright (A pillar users will love this).
So if you want the LEDs to be at 75% and the dash at 100%, just adjust the control to be that way and then as you dim the dash, the LEDs dim at the same rate.
More info to come and a prototype to be made this weekend.
maroonmetallic
central WI
Im only interested if you'll charge me 400% the typical price. /ubbthreads/images/graemlins/smirk.gif
-Shawn
Done. /ubbthreads/images/graemlins/grin.gif
This weeekend should be possible but pics would be of a prototype and not a finished "packaged" product.
But I could do a video if you want.
I just can't get too carried away. I have a TON of homework. I am in the middle of a 5 week accelerated course and they slam you with work.
But I will try and get it out to you all.
Then you are excused from LED class until this weeked /ubbthreads/images/graemlins/applause.gif. Now go do your homework & get off this site.
Just got home /ubbthreads/images/graemlins/grin.gif.
I am winding down for the night.
I will, however be doing 3 readings tomorrow night (4 Q&A pages each reading), 3 readings Thursday (4 Q&A pages each reading), working in the electronics lab Friday night, coast Saturday, spend Sunday finishing the opinions paper on the 6 readings, and Monday proof read everything for my Tuesday class. This class is "Cultures of the World".
But if it works out, I will have time Saturday to record/edit a quick vid and post up on youtube for your vuewing pleasure. (I hope)
DarkDevilMMM
Vacaville, CA
a simple 555 circuit will do the trick /ubbthreads/images/graemlins/smile.gif
oh, just a thought, why not make them a controller with auto brightness with respect to the brightness of the surrounding? Just need to add a photo resistor to the circuit with proper pot for uber coolness /ubbthreads/images/graemlins/smile.gif
14u2nV
Agency/St. Joe, MO
I want one to change the color of the gauges for two different boost settings,, low boost and high boost. /ubbthreads/images/graemlins/grin.gif
