Koni adjustables?
mooserage
Seattle, WA
I just aquired my first VR4 and it has KYB AGX in the back and I think it has Koni's in the front, (maybe AGX) but i cant see them. My question is how do I adjust the front dampers. I know you usually do it on the top, so thats where i started and all i have is a yellow tab. Do I turn this? Clockwise or counterclockwise? Do i gotta be gentle? Thanks for helpin a noob.
ken inn
krum texas
iirc, there are 2 types of koni, only 1 is adjustable. on the top, there should be a slot, like the tip of a screwdriver. you turn it clockwise to stiffen it up. total is 3 complete turns, the adjustment is infinite. a half turn will make a considerable change. you can get a white knob that fits on top, then put it in the glovebox so it dont get lost. only rebound is adjustable. there are no koni gas made for the vr4, so it is probably from t/e/l, which work fine with t/e/l springs. galant springs are a bit too harsh, because they are longer, and take a lot more preload. the tel strut is shorter than the galant.
AGX fronts have a 4-position adjuster on the top. You stick in a tiny flat screwdriver in the center, push down and rotate to 1,2,3, or 4. If lined up properly, the inner top gets flush with the outer ring. It might be behind a dustcap on the strut's top mount.
JNR
ca
I have some Koni adjustables on #20...There is a special 'tool' that came with them, to turn the adjustment screw, located on the top. I've never adjusted them since I've had them, so I can't think of what it looks like...IIRC though, it was a rod that stuck up with two flats on it, for a wrench (or this special tool).
[edit] yeah, like this:
On Koni's you need to turn the adjuster counter-clockwise to stiffen them. They usually have between 2-3 turns from soft to stiff, & as mentioned above they only adjust the rebound, compression is set. IMHO, they are way better than the AGX's. I am hoping to get a custom set of the new "race" Koni's for #1303 (shortened bodies & a lot stiffer valving) to replace my AGX's.
If you don't have one of the Koni adjuster knobs, just use a small 1/4" drive socket (I forget what size it is) that just squeezes over it & use a ratchet to adjust it.
