mk2davis
You guys are always so helpful. I'm hoping to tap your wisdom one more time... and no, I don't have a logger. ALTHOUGH I WOULD LOVE TO BORROW ONE!
I've been getting my dad's VR4 back into DD status, and it seems to be going well with a few nagging issues. When starting from a stop:
Gentle and slow with the throttle, no issues
50-70 percent throttle, pulls fine until 4k where it loses power, keeps boost, will buck if you don't pull out
100% throttle sometimes pulls like a scalded cat, sometimes pulls like a cat in slow motion, doesn't buck but keeps boost and just isn't that fast
The long block was a remanned motor with Felpro head gasket and APR studs, BSE, 16g small turbo, max 12# boost, rewired Walbro 190hp pump, and 2.5" exhaust.
New meaning 3 months old and 700 miles: NGK spark plug wires, NGK spark plugs gapped at .028", fuel filter, fuel pump, ISC, RC Injectors cleaned and blueprinted stock injectors, OEM FPR... I think I may be forgetting some things
Base timing was set correctly at 5* before the ECU was sent for inspection by ECMTuning. FIAV blocked off. Boost leak out of throttle body shaft.
Plan of action:
Replace Throttle body seals (most TB issues I've read about are at idle. This car's idle is rock steady at 850.)
Check TPS
I've read a bad CAS could lead to this? I don't just want to throw parts at this... It's bad for the body work.
I've read about some people replacing a transistor? I don't know where or what it does.
Besides this, I'm stumped. Please help me, OBGalant Kenobe. You're my only hope...
Plan of action:
Check TPS
