Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Re: PROJECT OF GALANT VR-4 1991
benjamin
Galant VR-4 org Post #: 1245051 posted 01/06/19 12:08 PM     Remind Me!  Send Private Message   Edit Post
Posts: 25 | | Member Since: 12/21/15 | IP: (37.98.60.164) | Report this post to a Moderator
benjamin
Galant VR-4 org Post #: 1245052 posted 01/06/19 12:14 PM     Remind Me!  Send Private Message   Edit Post
and i just change crownwheel and pinion VR-4 to EVO
and i save rear 4ws
benjamin
Galant VR-4 org Post #: 1245053 posted 01/06/19 12:23 PM     Remind Me!  Send Private Message   Edit Post
assembly rear caliper......
assembly front caliper....
138/2000
152/1000
Galant VR-4 org Post #: 1245056 posted 01/06/19 02:41 PM     Remind Me!  Send Private Message   Edit Post
Damn dude, car looks beyond good. The attention to detail is amazing I'm loving this build.
138/2000
152/1000
Posts: 3546 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (69.36.193.100) | Report this post to a Moderator
benjamin
Galant VR-4 org Post #: 1245068 posted 01/07/19 04:22 PM     Remind Me!  Send Private Message   Edit Post
thanks for your definitions
Posts: 25 | | Member Since: 12/21/15 | IP: (37.98.43.73) | Report this post to a Moderator
benjamin
Galant VR-4 org Post #: 1245069 posted 01/07/19 04:24 PM     Remind Me!  Send Private Message   Edit Post
brake rotor ....
benjamin
Galant VR-4 org Post #: 1245070 posted 01/07/19 04:29 PM     Remind Me!  Send Private Message   Edit Post
drive shaft assembly ..........
benjamin
Galant VR-4 org Post #: 1245071 posted 01/07/19 04:32 PM     Remind Me!  Send Private Message   Edit Post
benjamin
Galant VR-4 org Post #: 1245079 posted 01/09/19 04:03 PM     Remind Me!  Send Private Message   Edit Post
Posts: 25 | | Member Since: 12/21/15 | IP: (5.52.90.24) | Report this post to a Moderator
benjamin
Galant VR-4 org Post #: 1245082 posted 01/09/19 04:31 PM     Remind Me!  Send Private Message   Edit Post
STEERING POWER ASSEMBLY
FINISHING....
(painting_electroplating oil line Bolts and nuts _use new parts and repair kit)
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1245083 posted 01/09/19 06:35 PM     Remind Me!  Send Private Message   Edit Post
This project is making me look like I've never wrenched on my car before.
Looks really good.
1992 Nile black w/sunroof
Posts: 5867 | From: central Indiana | Member Since: 08/06/02 | IP: (199.66.65.59) | Report this post to a Moderator
benjamin
Galant VR-4 org Post #: 1245089 posted 01/10/19 04:54 PM     Remind Me!  Send Private Message   Edit Post
tanks for all guys .............
Posts: 25 | | Member Since: 12/21/15 | IP: (172.80.207.5) | Report this post to a Moderator
benjamin
Galant VR-4 org Post #: 1245090 posted 01/10/19 04:57 PM     Remind Me!  Send Private Message   Edit Post
steering pump front/rear
after....
benjamin
Galant VR-4 org Post #: 1245092 posted 01/10/19 05:15 PM     Remind Me!  Send Private Message   Edit Post
now i go to checkup the bushing
Red square : it means the rubber is not good (Just rubber the outer edges of the damaged) The interior rubber are quite healthy
green square : it means rubber is good
please see these pictures
now we go to make the polyurethane bushing....
benjamin
Galant VR-4 org Post #: 1245101 posted 01/12/19 11:51 AM     Remind Me!  Send Private Message   Edit Post
now we install the polyurethane
Posts: 25 | | Member Since: 12/21/15 | IP: (5.52.45.78) | Report this post to a Moderator
benjamin
Galant VR-4 org Post #: 1245120 posted 01/14/19 02:17 PM     Remind Me!  Send Private Message   Edit Post
now i want to show you amazing photo.....
Posts: 25 | | Member Since: 12/21/15 | IP: (195.181.169.144) | Report this post to a Moderator
benjamin
Galant VR-4 org Post #: 1245121 posted 01/14/19 02:22 PM     Remind Me!  Send Private Message   Edit Post
Edited by benjamin (01/18/19 06:16 PM)
Lesac
Galant VR-4 org Post #: 1245123 posted 01/14/19 02:51 PM     Remind Me!  Send Private Message   Edit Post
Quoting benjamin:
Iím pretty sure most of these photos are amazing
736/2000 sold
848/1000 current daily
Posts: 37 | From: OMAHA | Member Since: 12/09/18 | IP: (2620:0:1029:fd00) | Report this post to a Moderator
benjamin
Galant VR-4 org Post #: 1245136 posted 01/18/19 06:11 PM     Remind Me!  Send Private Message   Edit Post
this is amazing photo again...................
install the oil and gas line under the car
Posts: 25 | | Member Since: 12/21/15 | IP: (178.131.78.240) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1245143 posted 01/19/19 10:20 PM     Remind Me!  Send Private Message   Edit Post
Quoting benjamin:
brake rotor ....
Hi Benjamin, question for you.
Were those rotors sanded with an appropriate grit sandpaper as a final pass after the cutters were used?
Reason I ask, is because the rotor needs to achieve a non-directional surface finish and holding sandpaper to it and making an up and down oscillating motion with appropriate speed, will achieve this.
If they don't get finished this way, the surface the cutters left, will pull the pads outward as they pass over, resulting in a click or clunk noise/shudder. I only ask if these rotors are for permanent road use, or if they are temporary.
Love the build regardless, so keep those photos coming along!
C53A 1 of the ~1500
Posts: 1611 | From: THE Ottawa | Member Since: 03/05/05 | IP: (24.246.8.178) | Report this post to a Moderator
benjamin
Galant VR-4 org Post #: 1245150 posted 01/20/19 04:22 PM     Remind Me!  Send Private Message   Edit Post
hello sir thanks for your reply my topic
sir These rotor are temporary
The braking system will completely change in the near future
dont worry i know the original brake system not strong and i want to change it
Edited by benjamin (01/20/19 04:36 PM)
Posts: 25 | | Member Since: 12/21/15 | IP: (104.222.32.70) | Report this post to a Moderator
benjamin
Galant VR-4 org Post #: 1245151 posted 01/20/19 04:35 PM     Remind Me!  Send Private Message   Edit Post
amazing front complete axle....
benjamin
Galant VR-4 org Post #: 1245200 posted 01/26/19 03:21 PM     Remind Me!  Send Private Message   Edit Post
now i want to show you complete rear diff (amazing)
Posts: 25 | | Member Since: 12/21/15 | IP: (162.223.91.55) | Report this post to a Moderator
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1245217 posted 01/28/19 12:31 AM     Remind Me!  Send Private Message   Edit Post
Looking good!
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8891 | From: zompton | Member Since: 02/24/04 | IP: (75.86.151.204) | Report this post to a Moderator
benjamin
Galant VR-4 org Post #: 1245266 posted 02/02/19 05:07 PM     Remind Me!  Send Private Message   Edit Post
Posts: 25 | | Member Since: 12/21/15 | IP: (5.52.221.243) | Report this post to a Moderator
Pages: 1 | 2 | 3 | 4 | 5
2 registered and 26 anonymous users are browsing this forum.
Rating: *****
Generated in 0.032 seconds in which 0.012 seconds were spent on a total of 14 queries. Turbo powered.
