fuel supply and return hanger/clamps
joemoto
Pell Lake, Wi
I'm replacing the supply with -6AN and the return with 3/8 standard rubber fuel line so obviously original supports will are too small.
What hangers/clamps have people been using when replacing both lines? I've seen some double hangers for $10 - $20 a pop but that seems like a lot.
I've seen 10 packs of 6AN clamps that are designed to secure a single hose, any suggestions?
OldHairyBastard
Northern Chicagoland Area
Fabing something up yourself might be teh best way to go. Some kind of plastic or stainless brackets that you can use. Think outside the box.
kumfasa
Tauranga, New Zealand
If you take one of the stock clips off you will see that the plastic insert comes out leaving just the metal surround.This gives you a lot more space for the hoses and may be enough for your feed and return. Or at least give you a starting point to do some massaging of the stock clips to suit.
marvinmadman
Lafayette, Louisiana
I trimmed the stock plastic and had enough room to fit PTFE -8 and -6 in there.
