Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » The next chapter for 338/2000
biglady112
or what
359/2000
Galant VR-4 org Post #: 1193491 posted 11/07/14 06:11 PM     Remind Me!  Send Private Message   Edit Post
Olson just got back from a four year tour in Okinawa. 338 has been in storage the whole time at his parents house in Nebraska. He has some big ideas to get it ready for autocross and road race season for 2015. Knowing how things will pan out I offered to take car of all the maintenance and upgrades for him. I took delivery this morning of the car from the transporter. His dad was unsuccessful in getting it started for me and ultimately it jumped time. No big deal as we talked about going back to a stock head anyway. I will update what I can here as things progress. I am hoping it is only here for a month or so while I wait on some fabricated parts from my aluminum welder for the new setup.
New stuff will be-
Upgrade from V2 to V3 dsmlink
Speed density conversion
Remove the intercooler and make a hotpipe with two secondary injectors in the pipe
Run a whole new fuel system and remove the stock based system
Make a baffled fuel tank and mount it in the trunk
Go back to stock cams
New clutch because the stock one is slipping
Retune the whole car
Repair/replace the cylinder head
New timing components
And maybe some other small stuff. That is all I can think of right now. I will start by pulling the engine and transmission this weekend and moving from there. I will work on pics if I can.
I GIVE ZERO FUCKS. I HATE YOU ALL.
Posts: 1243 | From: Commerce City, Co | Member Since: 09/30/05 | IP: (216.4.56.185) | Report this post to a Moderator
biglady112
or what
359/2000
Galant VR-4 org Post #: 1193699 posted 11/10/14 11:26 PM     Remind Me!  Send Private Message   Edit Post
Posts: 1243 | From: Commerce City, Co | Member Since: 09/30/05 | IP: (65.128.96.205) | Report this post to a Moderator
biglady112
or what
359/2000
Galant VR-4 org Post #: 1193788 posted 11/11/14 10:38 PM     Remind Me!  Send Private Message   Edit Post
Jesus_Negros
Unempowered ADMIN
Galant VR-4 org Post #: 1193805 posted 11/12/14 09:40 AM     Remind Me!  Send Private Message   Edit Post
You don't waste time huh.
Quoting coyotes:
Just because you WANT your rare turd to be valuable doesn't mean it's gonna be.
Posts: 2332 | From: USA | Member Since: 01/07/12 | IP: (132.3.37.79) | Report this post to a Moderator
biglady112
or what
359/2000
Galant VR-4 org Post #: 1193808 posted 11/12/14 10:29 AM     Remind Me!  Send Private Message   Edit Post
Nope. Only about 12 hours into it with the engine removal. I replaced all eight intake valves as they did get bent. Replaced the rear main seal and cover gasket. Checked the bearings and cleaned all the parts. If all goes well I should have it and the tranny back in tonight and then onto the modifications. If my friends were to come help, vaginas, it would have already been running.
Edited by biglady112 (11/12/14 10:30 AM)
Posts: 1243 | From: Commerce City, Co | Member Since: 09/30/05 | IP: (128.177.161.143) | Report this post to a Moderator
Jesus_Negros
Unempowered ADMIN
Galant VR-4 org Post #: 1193812 posted 11/12/14 10:52 AM     Remind Me!  Send Private Message   Edit Post
At least you have friends
Quoting coyotes:
Posts: 2332 | From: USA | Member Since: 01/07/12 | IP: (132.3.37.84) | Report this post to a Moderator
biglady112
or what
359/2000
Galant VR-4 org Post #: 1193864 posted 11/13/14 12:49 AM     Remind Me!  Send Private Message   Edit Post
I did a few other things tonight so the motor did not go in. I put on an extra oil cooler housing as Jake decided he wants an oil cooler now. I cleaned the transmission a little. It really needs pulled apart and scrubbed or sand blasted. I have a parts washer and a blasting cabinet but, I am already doing this all for free, so I don't feel like tearing the transmission down and possibly having to rebuild it. It has 148,xxx miles on it now and was working just fine. I don't want to fix what isn't broken. I also had to pull some other parts that sold off the car and inventory all of Jake's childhood dolls and dresses his parents sent with the car. I just need to pull the timing belt cover off my talon and throw I on here before I slam the motor in. It has been snowing and been only as warm as 5* the last two days here in Denver and the talon is sitting outside under the snow. So it likely won't happen tomorrow as it will be cold again but, maybe Friday afternoon it will be warmer and I can get out there and pull it off. Once that stuff is done then I can start on the hotpipe conversion and new fuel system.
Posts: 1243 | From: Commerce City, Co | Member Since: 09/30/05 | IP: (128.177.161.183) | Report this post to a Moderator
biglady112
or what
359/2000
Galant VR-4 org Post #: 1193865 posted 11/13/14 12:55 AM     Remind Me!  Send Private Message   Edit Post
biglady112
or what
359/2000
Galant VR-4 org Post #: 1194032 posted 11/15/14 07:16 PM     Remind Me!  Send Private Message   Edit Post
2.5 hours to make these pictures happen.
biglady112
or what
359/2000
Galant VR-4 org Post #: 1194112 posted 11/16/14 06:34 PM     Remind Me!  Send Private Message   Edit Post
Stock fuel system removed.
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1194121 posted 11/16/14 07:48 PM     Remind Me!  Send Private Message   Edit Post
That tank looks to be in great shape. You reusing it?
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Posts: 3424 | From: SoCal | Member Since: 01/02/12 | IP:
(72.45.2.251) | Report this post to a Moderator
biglady112
or what
359/2000
Galant VR-4 org Post #: 1194134 posted 11/16/14 09:22 PM     Remind Me!  Send Private Message   Edit Post
No I am not. I am building a new trunk mounted tank for him.
Olson
Pwnd by Rance.
338/2000
Galant VR-4 org Post #: 1194146 posted 11/16/14 09:55 PM     Remind Me!  Send Private Message   Edit Post
Quoting GSTwithPSI:
You want it
338/2000
05 TDI Wagon
88 Raider
"Oh, and if you want to build your status and rank, go play some WoW. Come back when you're ready to talk cars". Qship
Posts: 1237 | From: Moreno Valley CA | Member Since: 10/08/06 | IP: (108.0.104.239) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1194147 posted 11/16/14 10:03 PM     Remind Me!  Send Private Message   Edit Post
I mean, I don't need it. But yes, I want it. A minty fuel tank would make a great addition to my parts hoard. I just don't know if I can afford it...
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
biglady112
or what
359/2000
Galant VR-4 org Post #: 1194151 posted 11/16/14 10:21 PM     Remind Me!  Send Private Message   Edit Post
It is perfect. I am not interested in shipping it however.
biglady112
or what
359/2000
Galant VR-4 org Post #: 1194224 posted 11/17/14 05:50 PM     Remind Me!  Send Private Message   Edit Post
I took two photos of the baffles before I welded the end of the tank on. When I went to upload them from my phone they were not there. I had to reset my phone and they were gone. Oh well. There are two baffles that run the lengths of the tank inside. It is 26"x18"x7" which is a little over 14 gallons. Now I will take it for finish welding. Parts are on the way for the secondary fuel injectors as well. Picked up a fuel pressure regulator and a bunch of sittings today as well. Moving right along.
biglady112
or what
359/2000
Galant VR-4 org Post #: 1194370 posted 11/18/14 07:59 PM     Remind Me!  Send Private Message   Edit Post
New fuel rail and grille.
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1194375 posted 11/18/14 08:19 PM     Remind Me!  Send Private Message   Edit Post
The new tank looks good. Just out of curiosity, why didn't you stick with the stock unit?
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
715/1000
1284/2000
Galant VR-4 org Post #: 1194384 posted 11/18/14 08:36 PM     Remind Me!  Send Private Message   Edit Post
CUZ, racecar!
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
biglady112
or what
359/2000
Galant VR-4 org Post #: 1194389 posted 11/18/14 09:21 PM     Remind Me!  Send Private Message   Edit Post
That is why. This car actually turns and is thrown around like they were meant to be. He was having starvation issues with the stock tank even with a full tank of fuel.
KiNgMaRtY
Member +++
802/1000
Galant VR-4 org Post #: 1194416 posted 11/19/14 10:01 AM     Remind Me!  Send Private Message   Edit Post
Great progress in such little time.
92 GVR4 #802 link
17 CTS-V,06 Evo IX MR, 98 Montero
94 MX5 M-Edition - On Xidas, LS1 Swap in progress
SOLD: 92 GVR4 #611
Posts: 793 | From: Corona, CA | Member Since: 04/08/08 | IP: (98.189.79.130) | Report this post to a Moderator
Jesus_Negros
Unempowered ADMIN
Galant VR-4 org Post #: 1194427 posted 11/19/14 11:58 AM     Remind Me!  Send Private Message   Edit Post
It would've taken me a year and a half to do all this.
Quoting coyotes:
Vr4junkie
writes like a tard
385/2000
Galant VR-4 org Post #: 1194433 posted 11/19/14 12:50 PM     Remind Me!  Send Private Message   Edit Post
Looks like it'll be running soon
385/2000 click
Posts: 596 | From: Some wack town in CA | Member Since: 06/25/11 | IP: (172.56.31.27) | Report this post to a Moderator
biglady112
or what
359/2000
Galant VR-4 org Post #: 1194435 posted 11/19/14 12:55 PM     Remind Me!  Send Private Message   Edit Post
I am just doing this in my spare time after work, usually after my training runs and before my wife gets home.
Posts: 1243 | From: Commerce City, Co | Member Since: 09/30/05 | IP: (205.197.242.188) | Report this post to a Moderator
coyotes
Hipster VR4
1226/2000
Galant VR-4 org Post #: 1194437 posted 11/19/14 01:03 PM     Remind Me!  Send Private Message   Edit Post
Quoting Turbro_Negro:
4+ years for most others
1226/2000
Posts: 1544 | From: Seattle, WA | Member Since: 11/15/13 | IP: (70.58.88.67) | Report this post to a Moderator
Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13
Rating: **
Generated in 0.338 seconds in which 0.273 seconds were spent on a total of 14 queries. Turbo powered.
