</font><blockquote><font class="small">Quoting Leon_R:</font><hr />
</font><blockquote><font class="small">Quoting alik:</font><hr />
Never mind the minting, accepted that there are more mounting options under the hood. However, in the interest of expanding my horizons and learning just a little bit more,
a)why the electrical problems?
b)kill switch, fine, but where?
c)really? How? Same weight is being moved to a different location. Box weight is negligible, so, why heavier?
Not arguing, mind you, just asking so I can form a better-informed decision.
Any time you deviate from the OEM solution, you expose yourself to problems! Now, car enthusiasts do modifications all the time, but usually there is some real reward for doing it. What is your reward for moving the battery? “Better weight distributing” for AutoX or Road racing? It is totally theoretical as actual change is minimal! And for drag racing, you actually want more weight in the front! Reliablity will be 100% depended on quality of parts, design and work. But even when done right, more components give you more opportunities for a failure.
As for weight, you will have few extra pounds of HEAVY wiring, battery box and a kill switch. But most people use full size (or bigger) battery in the trunk. So instead of saving a 15-20lbs, by using Odyssey, Miata or loan tractor battery, you end up being 10-15lbs HEAVIER!!! That is up to 35lbs of extra weight… and why, again? For the theoretical “better weight distribution” for road racing?
I can see doing this if you were really into audio stuff and needed extra battery capacity.
</font><blockquote><font class="small">Quoting EMX5636:</font><hr />
1. If done properly, I have done quite a few relocations with no problems, charging issues/etc.
Until... there are problems <img src="/ubbthreads/images/graemlins/wink.gif" alt="" /> Our cars often develop charging problems and when you have relocated battery, you have to first rule that out as the cause of your problem .
I think you are exaggerating a bit. 35 lbs? Everything you need to relocate to the trunk <i>might</i> put you in the neighborhood of 10-12 lbs. The main reason people move the battery to the trunk is to make that space under the hood available for other mods that can't be relocated to the trunk. I doubt anyone here does it for weight savings or better load distribution. There are quite a few members here who have relocated their batteries to the trunk and have never had issues. The charging system isn't negatively affected unless you've done something improperly, so that's a moot point IMO. Trunk relocation isn't the end all be all, but it's the best option for relocating a full size battery in my opinion. Relocating a small battery in place of the charcoal cannister is a good option as well.
